Navigation & Audio 2013 Satellite Radio Upgrade?
Old Oct 23, 2012 | 09:26 AM
Gambedegallina's Avatar
Gambedegallina
Have 2013 MCS with bluetooth, but not satellite. Lokking to add satellite. Dealer seems confused if needs just software/code purchase or receiver hardware as well. Any wisdom out there? Thanks.
Old Oct 23, 2012 | 09:29 AM
JoanieB's Avatar
JoanieB
Satellite radio requires equipment. The 2011s and maybe the 2012s came with it already, and a free year sub. The 2013s don't have it installed at the factory, so we just ordered it in our new MINI and it costs $250 I think, and comes with a one year sub.
Some people buy the equipment as a portable set, so that they can take it in different cars. You might look into that, though there isn't much space to mount it in a MINI.
Old Oct 24, 2012 | 12:58 PM
schatzy62's Avatar
schatzy62
2011 and 2012 only came with it if you ordered it. It was not standard.
As for ordering it when you order the car it may only be $250 but when having it added after the car is delivered is much more expensive.
There are many places to put a Sat Receiver in a MINI and many have done it. Just check out the posts in the NAV and Audio section there are a bunch of people that show thiers mounted as removable and how they did it.
Old Oct 24, 2012 | 03:07 PM
bmwr606's Avatar
bmwr606
sat radio was standard on my 2012 cms all4, the bluetooth was a $250 option
as i understand it, that has reversed on 2013 models, bluetooth is standard and sat radio is an option
scott
Old Oct 26, 2012 | 01:14 PM
Gambedegallina
2013 MCS; Satellite Upgrade
My vehicle has the hardware and wiring. It appears it needs the "enabling code" programmed in to activated Satellite radio option on car.
Dealer now reports that Mini says activation (enabling) code is not available for retrofit.
Note, BMW announced retrofit enabling code availability for MSRP of $375.00 with 1 year Sirius subscription in September for 2012-2013 BMW vehicles with hardware.
Does anyone have any different information? Mini part number would be the trick.
Old Oct 28, 2012 | 02:59 PM
amancuso's Avatar
amancuso
Sat radio was standard on 2012's mine had it as such.
Old Nov 15, 2012 | 08:19 AM
Gambedegallina
Now have Satellite. Car had all wiring and hardware. 0674 HK premium sound. Needed to purchase "enabling code" and have radio firmware programmed. Part no. 65-12-2-336-819. Now sit down. Cost $360 plus tax plus labor. Includes 1 year Sirius. It works.
Old Jan 28, 2013 | 03:38 PM
jax_on6's Avatar
jax_on6
2013 R59s Sirius
Gambedegallina- your post says you were able to get the Sirius enabled with the HK premium sound package 0674. Do you also have the satellite prep 0693? I only have the HK package so I'm not sure I can get Sirius enabled. Asked the dealer and they're going to check- they sounded really unsure about it. Thanks!
Old Jan 29, 2013 | 06:57 AM
Gambedegallina
Unfortunately, I can't answer the question as I had the same issue with the dealer. The spec print out I got from service advisor, from key fob data, I think, shows the 0674 HK premium sound, but does not list the sat prep. I have a faint recollection that when I took my VIN to the parts department, they were able to pull up the sat prep on the vehicle. The sat. coding part number (activation) was 65-12-2-336-819.
khumpert
Nov 30, 2015 11:48 AM
Zettinger
Aug 25, 2015 04:04 PM
Shane Wendel
Aug 18, 2015 01:13 PM
clintmeister
Aug 12, 2015 11:11 AM
veevsato
Aug 5, 2015 04:42 AM
