Navigation & Audio Mini Connected update released today
Old May 22, 2012 | 08:19 AM
  #26
nfo's Avatar
nfo
i successfully updated my R59 S with connected/nav. It was quick and painless via usb stick!
Old May 24, 2012 | 05:16 PM
  #27
Lil Maky's Avatar
Lil Maky
+1
In my case R58 S
Old May 24, 2012 | 08:46 PM
  #28
irieman's Avatar
irieman
Another +1! No noticeable difference though, in the 5 minutes I played w/ it.
One thing that kind of irks me though... In the Manual it says that the USB port inside the glovebox is only to be used for software updates. When I plug any other USB device in it (*cough*ipod*cough), it doesn't recognize it. When I plug in the USB with the software upgrade on it? It doesn't recognize that either. Might I have a dead glovebox USB port?
Old May 25, 2012 | 03:31 PM
  #29
Spice Orange JCW's Avatar
Spice Orange JCW
That USB is for nav updates.
Old May 25, 2012 | 05:51 PM
  #30
irieman's Avatar
irieman
Aah- interesting. Will have to read the manual closer next time.
Old May 28, 2012 | 10:30 PM
  #31
nfo's Avatar
nfo
works for charging the wife's phone as well!
Old Jul 19, 2012 | 05:56 PM
  #32
BigRed13's Avatar
BigRed13
Originally Posted by Mysticeti
Same thing for me. Your numbers match mine (MX-002.007.003/TX-002.007.003) and my vehicle is also a little over a year old.
So, has anyone found a fix for this? I tried unsuccessfully with my 2011 Mini Countryman S running .002.007.003 software. Tried both USB PORTS, even tried formatting the USB drive to make sure no other files were tripping it up.
I have posted a question to Mini as well... Will update if I get an answer.
Old Jul 20, 2012 | 04:23 AM
  #33
mjgood's Avatar
mjgood
My car was at the dealer for a week regarding this, they ended up opening a PUMA case with Mini.... end result from Mini was to software update the car, now everything is working as it should.
Old Jul 20, 2012 | 06:30 AM
  #34
schatzy62's Avatar
schatzy62
From MINI:
To perform such a software update, you require the following options:
‘Bluetooth mobile preparation with USB Audio Interface’ (option code 6NE) as well as the ‘Radio MINI Visual Boost’ (option code 6FP) or the ‘Navigation System Business’ (option code 606).
Your vehicle can be updated provided that you have the 'Software update' option on your 'Settings' menu.
If for some reason you do not have the 6NE or one or the other of the 6FP/606 options then you can not do the update yourself. Also if the software is slightly older and you do not have the Software Update Option in you r settings menu it will also not work.
Also of note is that most likely (even though not stated) the USB stick will need to be formatted for FAT32. Not FAT or NTFS those probably will not work. I know that FAT and NTFS do not work for playing music properly off of a USB stick.
Edit: and to properly format it to FAT32 you may need a program to do that as windows 7 and windows XP do a very poor job of formatting to FAT32.
Old Dec 3, 2012 | 01:23 PM
  #35
Jake273's Avatar
Jake273
Originally Posted by threar
I'm in the same boat as the others with the MX-002.007.003/TX-002.007.003 versions, no luck on the upgrade. Anyone found a way around yet?
Hi,
I've got the same problem (CooperS from 03/2011).
Has anybody found a solution in the meantime?
Or do we all have to visit our dealer?
Thanks,
Jake
Old Jan 15, 2013 | 02:42 PM
  #36
davydotcom's Avatar
davydotcom
Got the update to work on my 2013 but a few things to note. I could not get the USB update to be recognized on a newer jumpdrive that was 16gb in size. Could have been a weird issue, but I did get it to work with an older 4gb stick formatted in Windows 7 to FAT.
Also, when the USB thumb drive is plugged in(below center console), you may need to wait a second or 2 before the software update screen recognizes that it is indeed a compatible USB update. It told me it was incompatible then 10 seconds later it said (Ready to Update).
Also you do NOT need your car to be running to perform this update. It simply means, you cannot be in "accessory" mode to perform the update. The car needs to have its ignition on but does not need a running engine.
Old Jan 15, 2013 | 02:48 PM
  #37
davydotcom's Avatar
davydotcom
Also, I'm surprised noone has mentioned this, but it appears to have added "Time Shift" to Sirius satellite radio. You can go back in time up to 60 minutes of your satellite radio station like a DVR.
Another notable feature is when in a call:
Annoyingly the (End Call) tooltip would stay visible so you couldnt see the caller's name on the screen. This now hides after a few seconds and the callers name is visible.
Also if you have iOS6, certain features that worked before have been fixed (Messages seem to be coming through again). It looks like there was an update released as recently as November 2012 (UPD01005) Versions MX 3.5.4, TX 3.5.5
Old Jan 15, 2013 | 05:17 PM
  #38
MotorWorf's Avatar
MotorWorf
How can you tell what version you currently have?
Old Jan 15, 2013 | 05:27 PM
  #39
davydotcom's Avatar
davydotcom
I believe...
Settings -> System Update, you can see the current version on the System Update screen.
Old Jan 20, 2013 | 09:38 AM
  #40
Mysticeti's Avatar
Mysticeti
Looks like I'm still stuck with MX-002.007.003/TX-002.007.003. The November update wasn't accepted (same as previous update).
Old Mar 21, 2013 | 03:06 PM
  #41
amancuso's Avatar
amancuso
I have MX-003.004.031 and TX-003.004.031 Do I need this update?
YES! actually the new update is newer than the one in post 1 of this thread. FYI.
Last edited by amancuso; Mar 21, 2013 at 03:34 PM. Reason: Yes, I did need an update.
Old May 15, 2019 | 07:05 AM
  #42
Botschafter's Avatar
Botschafter
Reanimating this old thread because i have retrofitted Visual Boost with Combox Media in my R56.
Current Version is MX-002.007.003 and Update is allways rejected as not suitable for my car.
Usinf Fat32 formatted 2 GB USB Stick. Any solution to perform the Update?
Old May 15, 2019 | 10:59 AM
  #43
MrGrumpy's Avatar
MrGrumpy
I didn’t realize they were doing anything with it for the older cars. Did you use the USB port inside the glove box? I know that when I last updated mine, they said it had to be done with a usb stick in the glove box port.
Old May 15, 2019 | 12:47 PM
  #44
Botschafter
I tried both USB Ports. Audio USB and Glovebox USB. Same Message no update.
It was hard to find UPD01008.bin Because it is not available for my retrofitted car over regular download website.
It should be suitable for my Combox. I was hoping the is a solution to start the installation in my car.
Allready using FAT 32 USB Stick with 2 GB capacity. Ignition on.
Old Jul 17, 2019 | 10:56 PM
  #45
Semper Fi Huck's Avatar
Semper Fi Huck
What’s the latest version that’s out now, and where can I get it from?
Old Aug 10, 2019 | 07:37 AM
  #46
Botschafter
Latest Binary is Version 1008. I was able to update with USB but only after updating the Combox to version 1005 before. because mine was 1004 at start and there was no abilytiy to do the update with usb from that version.
it took me long to find that latest 1008. I uploaded it here to share it with you: Update 1008 Bin
Old Aug 27, 2019 | 03:43 PM
  #47
Joeyliv's Avatar
Joeyliv
My 2015 Mini Cooper Coupe JCW has Software version
multimedia MX-003.004.031
Telephone TX-003.004.031
Is there a newer version? Is there a way to update the navigation map? The car has Mini Connected and visual boost
I wish I could get Apple Carplay to work in the mini.
Old Aug 27, 2019 | 07:40 PM
  #48
Semper Fi Huck
Yes there is a newer version, and you can get it for free from the BMW website, there’s another thread that has a link to it. There are ways to get lifetime updates for around $20 for your maps from eBay, and once again there are other threads that have more information on that. And finally, yes you can get apple CarPlay, but you have to buy and install another plug and play piece of hardware...there are other threads that have links and more information on that too.
Old Aug 28, 2019 | 09:09 AM
  #49
Joeyliv's Avatar
Joeyliv
Any chance you have links to the threads?
bneer
Jul 15, 2019 04:41 PM
Dec 23, 2015 10:36 AM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
