Navigation & Audio 2010 R55 iPhone 4 Problem
Old Feb 20, 2012 | 05:50 PM
Norvigicus's Avatar
Norvigicus
I have a 2010 Clubman with a Y cable connecting to my iPhone 4 ios5.
It worked for over a yer until today when it stopped playing properly. It started by not recognizing where the iPhone's music was last at and starting on the first song. it will play (from the start) for 2 or 3 songs and then stop. I am no longer getting a song title display (non-NAV) and my shuffle doesn't work. The steering wheel controls only seem to work while the music is playing but after it stops its as if the computer is freezing.
I cannot switch to radio and back after it 'stops' but I am able to unhook the Y cable and replace but i does the same thing. It did start playing after fiddling but when I stopped and started it was back to the same thing. I also noticed the warning beep (lights, etc.) stayed on long after i shut off the car for the first time.
I should mention that I only recently upgraded my iPhone to ios5.
Please help!
Old Feb 21, 2012 | 05:29 AM
schatzy62's Avatar
schatzy62
First starting point is to disconnect the battery for more than 30 minutes.
People will tell you to just disconnect it and then press the brake pedal but that does not drain the power from the head unit computer. Let the battery stay disconnected for more than 30 minutes and see if that resets all the problems.
If it does let us know.
If it does not let us know and we can help trouble shoot farther.
Old Feb 21, 2012 | 09:15 AM
Norvigicus's Avatar
Norvigicus
Thanks, I'll have to give it a try after work.
Old Feb 21, 2012 | 12:25 PM
mikeyb74's Avatar
mikeyb74
I've been hearing alot about this issue lately. Is your Clubbie still under warranty? I just had MINI warranty the ipod/iphone Y adapter cable in mine because it was not working all the time. So if you are still underwarranty I would be giving the service department a call. But if disconnecting the battery works please let us all know.
Old Feb 22, 2012 | 10:07 PM
Norvigicus's Avatar
Norvigicus
It started working again by itself after being off all night. I will keep you posted.
ROCNDAV
Oct 20, 2015 01:08 PM
jziran
Aug 24, 2015 04:50 PM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:37 PM
Aug 11, 2015 12:34 PM
