Navigation & Audio Tweeters installation
Old Feb 12, 2012 | 04:11 AM
cvittas's Avatar
cvittas
Hello, I have a MC '07 with the BOOST Radio,
I would like to install tweeters in the A-pillars, does anyone knows how these are connected to the loom?
Any photos, would help a lot..
Old Feb 12, 2012 | 11:08 AM
strobeyprobey's Avatar
strobeyprobey
There is no wiring for A-pillar tweeters in a non-HIFI vehicle. The *main* vehicle harness is different.
Easiest thing would be to put the tweeters in the door.
The only alternative is to tap the wiring at X9331 and run wires up to the A-pillar.
Old Feb 12, 2012 | 11:38 AM
cvittas's Avatar
cvittas
Do you know which wires I have to tap at the X9331, to get signal for the tweeters?
Is there an X9331 for each side of the car?
Old Feb 14, 2012 | 05:48 AM
schatzy62's Avatar
schatzy62
There are a lot more quesitons to be answered to help you out on this.
1. are you changing all the speakers in the car?
2. are you adding an amp?
3. if you are not changing/adding the above are you only wanting to add tweeters and why?
Answer these and we can help you out with much better answers.
Old Feb 14, 2012 | 07:17 AM
cvittas's Avatar
cvittas
Hello,
First I would like to install the tweeters,to improve the quality of the sound.
If the result does not satisfies me, I'll change the speakers with better quality, like JVC.
I am not interested in installing an amplifier, I want better quality in the sound not loudness.
Old Feb 14, 2012 | 09:20 AM
Kevin@Integral Audio's Avatar
Originally Posted by cvittas
Hello,
Just adding tweeters to the existing system is not as simple as it may seem. The existing door 6" and 4" speakers are both run full range and in parallel, presenting a ~2ohm load to the HU front channels. Adding even an 8ohm tweeter to this mix would drop you to 1.6ohms, and a standard 4ohm tweeter would drop you to 1.3. I've never had occasion to test it, but I wouldn't be surprised if that sent the HU into short-circuit protection shutdown.
To avoid this, you'd need add a series coil to the "mid/woofer" combo in the door. You'd HAVE to add series capacitor to the tweeter anyway - you can't run the tweeter full range. The HU won't deliver enough power to burn a decent tweeter, but the distortion caused by asking the tweeter to produce a full range signal would far outweigh any benefits of adding it in the first place. It is possible that the inductive rise in the mid/woofer is enough that if you crossed the tweeter over high enough you wouldn't need a series coil on the mid/woofer, but you'd have to look at the impedance curve of the combined pair to know for sure.
Of course, by the time you've done all that, you'd have spent enough time, effort, and money that you'd be better off looking into a more comprehensive upgrade.
Old Feb 14, 2012 | 10:05 AM
cvittas's Avatar
cvittas
What do you suggest?
Old Feb 14, 2012 | 10:11 AM
What is your budget and your listening habits?
Old Feb 14, 2012 | 11:52 PM
cvittas's Avatar
cvittas
About 250$, I mostly listen to electronic music.
Old Feb 15, 2012 | 08:38 AM
$250 is a tough budget to do anything substantial with. That pretty much limits you to replacing just speakers. The problem is that the factory HU is very low power (about 8W/channel into the 2ohm factory load (see the sticky MINI Audio Basics), and the factory speakers are actually pretty well optimized for efficiency. There is a trade off between bandwidth (frequency response range) and efficiency, so if you want better frequency response range you are going to have to give up volume, and vice versa, unless you add an amplifier. This is complicated by the fact that a standard 4ohm aftermarket speaker will cut your available power in half. There is just no way around any of this unless you add an amp.
If you are limited to the $250, you could look at putting a 3.5 coax in the mid location and a 6" coax in the door. Two 4ohm sets in parallel will keep you at 2ohms and maintain your full 8 watts. You will get some terrible comb filtering due to the complete overlap in two sets of speakers, but this is no different than the existing factory setup and will at least have the benefit of adding tweeters with some better high freq response.
My recommendation, though, would be to save your $250 and wait until you can increase your budget - your actual value/improvement for your $250 doing the above will be quite low.
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
