Navigation & Audio How to properly install door speakers
Old Nov 20, 2011 | 07:20 AM
BobbyTheLee's Avatar
BobbyTheLee
The voice coil on one the the HK door speakers got pinched last year and I've been driving around without that speaker for a while now. I finally bought a Polk db6501 set but when I installed the new woofer I barely get any sound. I felt around the edge of the speaker and there is tons of air flowing around it. I guess that I need some sort of insulation between the speaker and the door but in all of the posts I've never seen anyone mention that it's needed. I just want to make sure that is the problem before I go spending $ putting dynamat around the speakers. I've seen people talk about creating MDF adapters but I wouldn't think that MDF would conform to the door any better than the plastic mounting ring.
Old Nov 22, 2011 | 10:17 AM
Kevin@Integral Audio's Avatar
Not sure what you mean by "pinched" (did it do something illegal and get arrested? ). There are range of possible problems here. Post a pic so we can see how you mounted the driver. If there are large gaps or holes between/around driver and baffle it will cause cancellation, but unless you did something really funky with the mounting I doubt that is your issue.
I suspect that the problem lies with the signal the speaker is (or isn't) receiving, or that it is defective. How much sound is "hardly any"?
Keep in mind that's a full-range coaxial speaker you've attached to a speaker that only gets lower frequencies from the amp. So if the "hardly any" sound is in reference to a lack of highs from that speaker, that's why.
Old Nov 24, 2011 | 01:56 PM
Jo-Way's Avatar
Jo-Way
Do you have an unnecessary spacer? I just changed out the speakers in my MINI and the spacer that was given to me by Crutchfield didn't fit, for one, and two, wasn't need. I fit the speaker in with the bracket that was in the Polk box instead of using that Metra or Scosche part.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Super Coop
Aug 17, 2015 05:09 PM
OutMotoring
Aug 6, 2015 09:32 AM
