Navigation & Audio iPad iPhone feedback when connected -help!
Old Oct 10, 2011 | 07:26 AM
slimjimtell's Avatar
slimjimtell
When I connect my iPad or iPhone into the MINI Y cable, I get a lot of feedback. Hissing and whistling.
  • I tried another griffin cable...same thing!
  • I tried to hook them both up by ONLY a headphone type cable...same thing.
  • Put both devices in airplane mode to see if it was the 3G...same thing.
  • My INNO satellite radio doesn't do this.
  • My 1st Gen Itouch doesn't do this either.
I have the Harmon Kardon, NO NAV radio.
Anyone else have this issue with IPhone or iPad?
Old Oct 12, 2011 | 04:53 PM
slimjimtell
Surely I am not the ONLY person having this issue!
I tried the following noise reduction cable and it Does eliminate the noise, ALTHOUGH, it makes the iPhone now sound terrible. Almost transistor radio quality...maybe not that bad, but it seriously degrades the sound.
Does ANYONE have a solution?
http://www.amazon.com/Kensington-Red.../dp/B0031U1ATQ
Old Oct 13, 2011 | 07:45 AM
schatzy62's Avatar
schatzy62
Sounds like you might have a missing ground on the AUX input. That would cause this problem although it should (but not always) show the problem on all devices hooked up to the AUX input.
Questions
How do you have your INNO hooked up to the audio system?
And are you using the same cable for the iPhone and iTouch?
Old Oct 22, 2011 | 02:46 AM
slimjimtell
iPad is still not working properly, it thinks is a bad output.
iPhone 4S is working flawlessly!
Old Oct 25, 2011 | 09:20 AM
MiniAJ's Avatar
MiniAJ
Yeah same thing happens to my 2012 r56. yeah it's annoying as hell I've been using the satellite radio for the last month.
Old Oct 26, 2011 | 09:19 PM
thunderball kaboom's Avatar
thunderball kaboom
I had as similar problem she I upgraded to an iPhone 4. The phone is causing the feedback. I solved this by using a Fiio brand cable that connects the Aux port to the dock connector port, rather than the headphone port. It's here:
http://www.amazon.com/FiiO-20-Inch-L...9688889&sr=8-1
The sound quality is great, but it does eliminate the ability to use the phone through the radio (a connection through the dock port cuts off the mic on the phone). You can still use the phone with via bluetooth.
donniedarko
R55 :: Clubman Talk (2008+)
Jan 18, 2016 06:17 AM
pglgp1292
Oct 5, 2015 06:47 PM
jennster
Sep 28, 2015 06:19 PM
krohm
Sep 28, 2015 12:16 PM
dragonby
Sep 25, 2015 08:10 PM
