Navigation & Audio Replacing HK amp with E46's HK amp - Works!
Old Oct 18, 2012 | 05:38 AM
  #26
seamill's Avatar
seamill
Bump. Anyone....?
Old Oct 19, 2012 | 10:01 AM
  #27
Bradley99's Avatar
Bradley99
A drawing of the rear interconnect board (RIC) is attached. I think this view is from the rear, or outside of the amplifier. The Mini's wiring harness connects to the RIC through P1 and the PCB connects through S1 and S2. The RIC is a multi-layer PCB that makes the connections between P1 and S1/S2. The shorting connections mentioned in merongi's posting, 8 to 9, 16 to 17, 29 to 30, and 37 to 38 are P1 connections which can be made to the back side of the P1 connector on the RIC. These are shown as red connections on the figure.
You shouldn't have to remove the amplifier board from the housing - only the RIC. It has been a while since I did this and I am just digging through my old documentation so I suggest you double check the pin numbers on the P1 connector to be sure that the figure is correct with the posted modification.
Old Oct 19, 2014 | 07:56 AM
  #28
rollsrock25's Avatar
rollsrock25
I used the original post on this thread and followed the 3, 2, 1 done process last night on the e46. I just wanted to say THANK YOU, thank you, thank you.
Old Jan 25, 2018 | 08:19 AM
  #29
mini1275GT's Avatar
mini1275GT
Re-programing HK amplifier
Hi all,
I know this is an old thread and for R50 Mini. I have a 2010 R56 with HK system and have no sound. Found a used amplifier to replace but need to know how to scan/program the replacement amplifier.
Thanks-Giorgio
Zettinger
Aug 25, 2015 04:04 PM
PrimePower
Aug 16, 2015 06:29 PM
Lee-Oh_825
Aug 11, 2015 10:27 PM
Lt. Dan
Aug 10, 2015 08:23 AM
CARdiac
Aug 8, 2015 03:30 PM
