Navigation & Audio which iPod/iPhone interface works with HK audio?
I just found out through Crutchfield that the DICE Electronics iPod/iPhone interface does not work with the Harmon Kardon audio system.
Which ones do?
Crutchfield said the following:
Apparently the factory Harman Kardon system in your MINI doesn't use the same protocol and/or connections as the non-Harman Kardon system. If your factory stereo has DSP, you can use this iPod adapter from USA Spec:
http://www.crutchfield.com/cgi-bin/P...p?i=581PA12BMD
If the factory stereo doesn't have DSP and has CD changer controls, you can use this adapter:
http://www.crutchfield.com/cgi-bin/P...sp?i=541ISBM72
I know this may not have been the information that you were hoping for, but if you decide to make a purchase, simply finish filling out our online order form here:
http://www.crutchfield.com/cgi-bin/viewcart.asp
Thanks again for your e-mail. Please let me know whenever you need anything else.
Chuck
Which ones do?
Chuck
07-16-2020 12:54 PM
12-23-2015 10:36 AM
