Navigation & Audio Radio static sound
Old May 6, 2010 | 05:58 PM
05Greenie's Avatar
05Greenie
Radio static sound
I have an 05 R50 and recently have noticed a low static sound when listening to the radio, stations that I always listen to never had this static sound, now does. One observation is at idle the static sound is low, when I depress the throttle and the engine RPM's increase the static sound increases and decreases with the engine RPM's. This is not a case of poor reception. Does anyone know what is causing this and how do I repair it?
I have the stock radio and speaker setup, I have not modified or tinkered with any wiring in the car.
Thanks,
Mark
Old May 6, 2010 | 06:06 PM
Fatherdeth's Avatar
Fatherdeth
Sounds like you have a bad ground in the stereo system. Even though you haven't changed the stereo from stock, these things can happen. My whole driver's side speakers had a short in them. When I upgraded and pulled all the stock components out, I noticed loose wiring in the OEM harness. I fixed this and it's sounded like new ever since. It's worth a shot for you to check the grounds in the stereo system.
Old May 6, 2010 | 06:56 PM
05Greenie's Avatar
05Greenie
Thanks...I'll check it out....
Old May 6, 2010 | 07:25 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
I have the same issue..
One day i heard REALLY bad popping static sounds in my left speaker..
I took the stereo out the back the next day and turned on the car before i touched any wires and it went away...
and earlier today i just heard a small zapping sound in the right speaker.. wtf
Old May 7, 2010 | 04:05 AM
Fatherdeth's Avatar
Fatherdeth
If you look at the OEM harness, the wires are not installed the greatest. They are pushed into the connector and no solder is used. Over time, they can work their way out a little and cause bad connections.
Old May 7, 2010 | 09:44 AM
05Greenie's Avatar
05Greenie
As my son would say " a fatal mini flaw"....
Old May 25, 2010 | 10:01 AM
Gerldoc's Avatar
Gerldoc
Thanks,
Mark
OMG - I have the same issue - exactly! Static sound that increases when I step on the throttle/increase RPMs ...Did you try what "fatherdeth" recommended yet, did it solve the problem?
Melanie
lweaver
Sep 17, 2024 08:22 AM
Colt45Magnus
Aug 27, 2024 05:03 AM
Supertractor3
Apr 7, 2017 11:16 AM
molala
Oct 2, 2015 01:53 PM
