Navigation & Audio Mission Control can be retrofit! Woohoo!!!
Old Dec 5, 2011 | 03:10 PM
  #26
Spice Orange JCW's Avatar
Spice Orange JCW
Originally Posted by SCMountaineer
Thanks! Do you know if its one of the features that requires the snap in adapter? (guessing it must be since it, along with dynamic music, dont show up on my list of choices on the screen even though they show up on the app when the device is not plugged into the car.)
I'd like to have it just for the gee-whiz factor and for when my nephews are in the car. I cant imagine using it on a daily basis.
As long as you Iphone has IOS 5.0 or higher the mission control and dynamic music should be listed. If you do not have higher than 5.0 then the only way to use it is a snap in adaptor.
Old Dec 6, 2011 | 08:51 AM
  #27
strobeyprobey's Avatar
strobeyprobey
Originally Posted by christomapher
What I wonder is if the non-Mission Control-equipped MINIs actually have all of the necessary components to deliver on the entire experience... I wonder if all MINIs have accelerometers or gyroscopes that activate these exclamations for Mission Control.
Yeah the Mission Control unit is monitoring the CAN bus for data coming from presumably the DSC, DME, SZL and other modules. And that 9/2009 build date requirement does/could mean that those modules will not put that data out on the data bus if you have an older build date.
Old Sep 19, 2012 | 08:46 PM
  #28
sillyapple's Avatar
sillyapple
can the retrofit kit be installed in a non-navigation version of 2011 Countryman ?
GregoryK
Dec 14, 2015 01:34 PM
MyOrangeOne
Navigation and Audio
Sep 28, 2015 05:04 PM
voip-ninja
Sep 16, 2015 01:50 AM
bbak11010
Sep 7, 2015 08:08 PM
bbak11010
Sep 7, 2015 08:03 PM
