Navigation & Audio MINI & Auto Shut Down at the Drive-In
Old May 25, 2008 | 08:47 AM
Mini*In*Flux's Avatar
Mini*In*Flux
Last night bf and I went to drive-in and since it was a bit chilly we decided to take Kirky instead of the Wrangler.
Everything was perfect until everything shut down about 25 minutes into the movie (fumble - balance sushi on left hand - search for fob with left hand - put fob in - take fob out - turn on sound system). A routine that was repeated many times over during the double feature (Indiana Jones / Iron Man).
I checked the manual but I could not find any way around the automatic turn off. Any suggestions?
Old May 25, 2008 | 09:30 AM
LOP's Avatar
LOP
maybe keeping the fob in the ignition after turning vehicle off? Try it, not sure if it will work.
I know that if I put the fob in and press the start button WITHOUT stepping on brake, then everything turns on and I can listen to the radio.
I have convenience access so this also works without key in ignition.
Old May 25, 2008 | 04:37 PM
steaming79's Avatar
steaming79
ignition on, just not the engine. stayed on for over 40 mins last nite when i was just sitting around before i got out.
Old May 25, 2008 | 04:55 PM
Mini*In*Flux
Thank you for your suggestions! I did consider leaving the fob in the ignition but since we were watching a double feature (about 5 hours) I was afraid of running the battery down.
Old May 26, 2008 | 06:10 PM
DOGTOR's Avatar
DOGTOR
I had this EXACT same issue last night as well!! Except I was seeing Iron Man and Made of Honor . The radio would turn off after about 15 minutes. After reading through the manual extensively and fiddling with the controls, I gave up. After happening twice, I ended up just pushing the start button without turning the car on. I really didn't want to do this because I was afraid of draining the battery. But, fortunately, no battery issues.
On a different note, lowering the rear seats and opening the barn doors on the Clubman makes a great drive-in bed
iggi
18
Feb 9, 2026 01:00 AM
Dec 23, 2015 10:36 AM
wind715
Aug 11, 2015 07:56 AM
Lt. Dan
Aug 10, 2015 12:46 PM
