Navigation & Audio Front door panel removal
I have a 2006 mini s convertable, can someone please tell me how to take the door panals off and also the rear panals so i can swap out the speakers? thank you, i did find some help but the panals are not like mine. i can see 2 torx screws in the door and i think one is behind the reflector, but i want to make sure what else has to come off or how to pull it off without srecking the panal or clips. where is the hk amp in my car? i have not looked yet but that will be comming out. thank you for any help
Here is a good step by step on taking out the door panels.
http://www.jwardell.com/mini/hkdoor.html
Hope it helps.
Hope it helps.
Ok , got the head unit in, noit much room for all the wies but i go it all in and have the rca's and remote wire tucked up in the cover under the steering wheel for now till i figure out how to get the side rails under the door in th ebody off to hide them all the way to the back. i got eh door panals off only to realize i have to make a 1 1/4 inch thick adapter so my magnets don't hit the power window rails lol well im off to bed its late so i will try more later, i have to mount 2 amps and wire them up should be easy since my battery is in the rear.
What front speakers are you using that require a 1.25" spacer? I'm looking at the Infinity Kappa 60.7cs speakers for my convertible, and the top-mount depth is 2-3/16", which I *think* will fit without spacers.
Also, did you find a reference that told you how to remove the front door panel, or did you figure it out on your own? I'm looking for the same information.
Im useing my old boston acustics that i had in my 3000gt, thay are 3" deep with a big *** magnet so i have to make spacers like the originals had. heres th links i used to remove the doior panals, have not gotten to the back part of the car yet.
http://www.gbmini.net/G2/v/General/G...oval5.jpg.html
http://gbmini.net/downloads/PGEN/
https://www.northamericanmotoring.co...ad.php?t=84200
https://www.northamericanmotoring.co...handle+install
Thank you Mini bee
i got the door panals off per the links i found and added to this, just have to make spacers and figure out how to get the side kick panals off under the door along the door opening edge
Glad to help. Do you mean the door sills? Those are held on by a bunch of clips I believe, and you have to remove the metal door sill insert to get to some screws. People have described using a hot knife to loosen the adhesive and get those metal sill inserts off.
crap, im not gonna unglue anything lol i will try and pry it up enough on the inside edge near the capet and tuck them under, have to wait for no rain, its raining now till sunday. oh well.
Ok, i give up in the friggin hk amp, i got the door speakers set, had to cut into the harness under the dash and run wires back to my amp, wich is not in yet, ran the rca's from the new deck back also. getting the rear panals off is a pain in the A#@ in a convertable, it got so cold i gave up after getting the seats and crap out, it looks like the top has to come down to get the panals off, its dark and im beat lol so i will leave it apart and do more another time, there are 6" round speakers back there not 6X9's, I have not decided on where to put my 2 amps yet but i like the fact the battery is in the boot area.
2003 Door Panel Removal
Hope it helps.
Hope it helps.
I have an 06, theres a toex screw under the round reflector on the door panal, there one under the arm rest pad, to get the pad off on my 06 you have to slide a thin thin butter knife or plastic knife under the forward part of the rest to release the clip that hod it in place. the res of the screws you can see, there might be one under the tweeter cover too, i can;t remeber i did it so long ago. hope this helps
R50/53 Respray - Color Change?
chicohuahua
22
Aug 20, 2015 11:17 AM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
