Navigation & Audio Bluetooth compatibility list
  #26
Old 02-26-2008, 10:36 AM
Birdman's Avatar
Birdman
Birdman is offline
The Samsung BLACKJACKS:
Blackjack 1 (SGH-i607): Running WM5, as posted, NO phone book integration. HOWEVER, if you upgrade it to WM6 now available, everything works perfect in the MINI.
Blackjack 2 (SGH-i617): Everythijg works perfect. You incorrectly posted there is "no phobnebook integration". But the phonebok works fine.
  #27
Old 02-26-2008, 04:40 PM
ualwoody's Avatar
ualwoody
ualwoody is offline
Sprint - 6700 Pocket PC (UT Starcom)
My Sprint 6700 phone links and integrates the directory just fine.... however every 5-15 minutes it partially drop the link and where I can originally see the name of my phone on the title, it then changes to something like this: D6:67:76:XL:M7 Now I didn't copy the exact #, but it loses the link and will not operate until i turn bluetooth off and then back on. Anybody experience this?
I am looking at the Sprint "Touch" phone, any input on that one yet? If that one doesn't work, I will probably get the Blackberry as that seems to be the most compatible.
  #28
Old 02-26-2008, 07:54 PM
dominicminicoopers's Avatar
dominicminicoopers
dominicminicoopers is offline
Just going by what post #6 reported.
  #29
Old 02-27-2008, 09:57 AM
Birdman's Avatar
Birdman
Birdman is offline
They are doing something wrong. The Blackjack 2 integrates perfect right out of the box. Bluetooth reception is perfect, phonebook integration is perfect.
  #30
Old 02-27-2008, 10:00 AM
Birdman's Avatar
Birdman
Birdman is offline
Originally Posted by LOP
OK=Samsung Blackjack II (no phonebook integration)
You sure? I have several BJ2's, they all work perfect right out of the box. The address book syncs, you can dial address book entries, when calls come in, the name is displayed if the incoming phone #(caller id) matches one in the address book. Missed calls show up fine....
  #31
carjoy's Avatar
carjoy
carjoy is offline
Hey Dom!
My Verizon LG VX9900 works great with the bluetooth. The switch over from using my Motorola Razr to this phone went very well. No problems with downloading my contact list either.
cj
  #32
Old 02-27-2008, 10:22 AM
dominicminicoopers
Birdman, I appreciate you trying to assist LOP, but can I ask you to contact them directly (via PM) so that you can assist them in getting their blackjack to sync properly (probably a software version issue) Let's keep this thread to go's and no-go's.
  #33
Old 02-27-2008, 01:42 PM
marrlin's Avatar
marrlin
marrlin is offline
w580i good
Sony Ericsson w580i works perfectly.
Nokia 6620 works; no phonebook though
  #34
Old 02-28-2008, 10:06 AM
nicknbecka's Avatar
nicknbecka
nicknbecka is offline
Someone over on Mini2 with a Sony Ericsson K850i had the same problem as the Treos: http://www.mini2.com/forum/2nd-gen-f...son-k850i.html
  #35
Old 02-28-2008, 12:04 PM
nicknbecka's Avatar
nicknbecka
Okay, so I've been phone shopping:
Blackberry 7520 synched successfully
Blackberry 8703e works, per this post
Blackberry 8800 works
Blackberry 8830 works, pairs and syncs
HTC 3300 Pocket PC Phone Edition works
i-Mate K-JAM (WM5) works and syncs
LG VX5300 works
LG VX6700 Win Mobile PPC, intermittent
LG VX8300, also works with everything,
LG VX8550 Chocolate pairs, possible voice dialing problems
LG VX8600 works, including phone book sync
LG VX8700 pairs and syncs, possible voice dialing problems (work around?)
LG VX9800 EnV Orange works, takes a long time to sync initially
LG VZ9900 (Verizon) works, pairs and syncs
Nokia 6103 synched successfully
Nokia 6133 synched unsuccessfully
Nokia 6310i works, cradle available (part no: 84 21 0 304 651)
Nokia 6882 works
Motorola L6 successfully pairs
Motorola E815 works
Motorola KRZR K1m works
Motorola Q9M (Verizon) works, but no phone book, may need firmware update
Motorola RAZR V3m (Verizon) works
Motorola RAZR V3t works
Motorola RAZR v50 works
Motorola SLVR (AT&T) works
Motorola V551 does not work, or maybe it does?
Motorola V555 does not work
Motorola V557 works
Samsung A-737 works
Samsung A-870 does not work
Samsung M300 (Sprint) works
Samsung SGH-620(?) works
Samsung SCH-A950 works, sends and receives calls phone book unknown
Samsung SCH-u140 works
Samsung SPH-A900 might work, but must be re-paired for each start of the car
Samsung SGH-D900 pairs, but disconnects after about five minutes (maybe a power save issue?)
Sanyo Katana works
Siemens SK65 synched successfully
Sony Ericsson 520 works
Sony Ericsson K750i works pairs syncs and voice recognition
Sony Ericsson M600i (UIQ3) works pairs syncs and voice recognition
Sony Ericsson W800i works, pairs syncs and voice recognition
Sony Ericsson W800a works, pairs syncs and voice recognition
Sony Ericsson W810i has a cradle available
Sony Ericsson W950i (UIQ3) works, pairs syncs and voice recognition
T-Mobile Dash works
T-Mobile MDA III Compact (HTC 3300) works
Treo 700wx works, but must be reset for each start of the car
UT Starcomm 6700, works but is interrupted by powersave functions
  #36
Old 02-28-2008, 12:08 PM
nicknbecka's Avatar
nicknbecka
Also, a list of armrest snap-in part numbers from http://www.bimmernav.com/snapins.html:
Formatting is kinda borked, sorry. EDIT: Fixed width fonts to the rescue...
Another EDIT: These snap-in part numbers seem like they might be mixed with some part numbers for cars using I-BUS, you should probably have a dealer check to make sure it's compatible with your car before you order the wrong one and demand I be flogged
Code:
No. Description       Supplement           Part Number   Notes
01  ADAPTER SNAP-IN   SIEMENS S55, S56     84210154606   Phone Software Version 91 or higher
01  ADAPTER SNAP-IN   NOKIA 6310 & 6310I   84216930108   Phone Software Version 5.51
01  ADAPTER SNAP-IN   ERICSSON T39M, T39   84216925216   Phone Software Version R3A022 or higher
01  ADAPTER SNAP-IN   ERICSSON T68I, T68   84210303561   Phone Software Version R7A005 or higher
01  ADAPTER SNAP-IN   NOKIA 6230I          84216973983   Phone Software Version 3.25 or higher
01  ADAPTER SNAP-IN   NOKIA 6020, 6021     84210413190   NEW! 03/06
01  ADAPTER SNAP-IN   NOKIA 6100, 6220,    84210413033   NEW! 03/06
                      6230, 6230i, 6610,
                      6820, 6822, 7210,
                      7250, 7250i
02  ADAPTER SNAP-IN   SIEMENS S65, S66     84210392326   Phone Software Version 12 or higher
    ONLY WITH: SNAP-IN ADAPTER COVER       84210306467 Required adapter Cover for Siemens S65
02  ADAPTER SNAP-IN   ERICSSON K750i       84219116566   NEW! 03/06
02  ADAPTER SNAP-IN   ERICSSON T610, T616, 84210304298   Phone Software Version R7A011 or higher
                      T618, T630, T637
    ONLY WITH: SNAP-IN ADAPTER COVER       84210306467 Required adapter Cover for ERICSSON T610, T616, T618, T630
03  ADAPTER SNAP-IN   MOTOROLA V710, E815  84210393570
03  ADAPTER SNAP-IN   MOTOROLA RAZR V3     84210415023   P/N ONLY FOR E90, E60, E65, E66
03  ADAPTER SNAP-IN   MOTOROLA V600, V551, 84210307726   Phone Software Version 0B.09.38R or higher*
    V535, V505, V525, V635, V330 adapter Trim may be required P/N 84210306467
  #37
Old 03-02-2008, 12:37 PM
minicounter's Avatar
minicounter
minicounter is offline
nicknbecka - thanks for the summary (with footnotes)
  #38
Old 03-03-2008, 08:13 AM
Otra's Avatar
Otra
Otra is offline
Wow, nicknbecka - very impressive!
Here's a question from a real novice - what is the difference between something that "works" vs "and syncs" vs "and pairs"...in other words the finer points? I ask because I currently have an LG5300.
  #39
Old 03-03-2008, 09:05 AM
nicknbecka's Avatar
nicknbecka
The general order of worst to best is probably:
Pairs -> Reliable Connection -> Dials -> Phone Book Syncs
I figure, better safe than sorry- but there's no reason to assume that there would be problems with one marked "pairs" as opposed to "syncs" or "works" just because. Most likely I'm just being picky.
Basically, I just went through all of the cell phone/bluetooth/armrest threads I could find over the past three or four months and re-posted what specific information I could find- if the original poster (the post that I linked) didn't specify, I tried not to make any assumptions.
The only reason I did it this way, is that some phones have been reported as "works", but then later someone would post that the phonebook wouldn't sync for them, or they would get dropped calls. Note that the Motorolla V551 has conflicting reports
For all I know, it's not a problem with that particular model phone- I've had a Sony Ericsson T610 that had trouble pairing with a Bluetooth headset after I dropped it, but my wife's worked fine. Some phones only work after a firmware update (Seems to be the case for the Motorolla Q) or an upgrade from Windows Mobile 5 to Windows Mobile 6. It'll be tough to say for certain until there's been more than one or two people trying the same model- Phones like the RAZR or many of the Blackberries have lots of reports that they work.
I was thinking it might be a good idea to come up with a Mini Bluetooth Matrix that's a bit more specific. Something like:
Code:
Motorolla:
Phone Model | Pairs | Dials | Sync | Voice | Notes:
RAZR V3        Yes     Yes    Yes     Yes     Armrest Snap-In Available, Part No: 84210415023
Palm One:
Treo 700p      Yes     Yes    Yes     Yes     Known Issue: Corrupts MINI Bluetooth module after repeated phonebook syncs
Samsung:
SPH-A900       Yes     Yes    Yes     ?       Reported Issue: Must be re-paired with each start of the car
  #40
Old 03-03-2008, 09:15 AM
nicknbecka's Avatar
nicknbecka
Also, I tried not to duplicate any of the phones in dominicooper's original post, unless there were some additional notes. The intent was to make it easier for them to cut & paste it into the top message.
  #41
Old 03-03-2008, 10:04 AM
nycooper's Avatar
nycooper
nycooper is offline
My cousin just asked me to set up his phone. He just got an account from T-mobile and he is using the Motorola W490 The phone pairs flawlessly and syncs without issues. It dials no problem but I have not tried voice dialing. Will try tomorrow.
  #42
Old 03-04-2008, 03:24 PM
nicknbecka's Avatar
nicknbecka
Good: Nokia N73 (No Phonebook) [Mini2]
  #43
Old 03-06-2008, 05:24 AM
spiney's Avatar
spiney
spiney is offline
Nokia 6086 works
Phone book sync, dialling, call pickup, the works
To get it to pair, you have to use Settings->Connectivity->Bluetooth->"Search for Audio Enhancements" while the MINI is in pairing mode, otherwise it will not hook up.
  #44
Old 03-07-2008, 08:58 AM
Birdman's Avatar
Birdman
Birdman is offline
I'm trying to assist you. The list is incorrect. The Blackjack 2 works perfect. There are no software revisions to it. Only one release, WM6, and it works right out of the box with MINI including the phonebook integration. You should update the list.
Ps- there is only 1 Blackjack 2. It's model is SGH-i617. You have it listed twice.
  #45
Old 03-07-2008, 11:58 AM
Otra's Avatar
Otra
Otra is offline
Thank you again - and for the explanations, too!
  #46
Old 03-09-2008, 07:12 AM
dominicminicoopers
I seem to have lost thread notification so I wasn't getting an email when someone replied to this post. I appreciate all of the hard work people had done to gather information, especially nicknbecka for his exhaustive lists (well I got exhausted from all of the copy and pasting I did).
  #47
Old 03-09-2008, 07:20 AM
dominicminicoopers
When I get conflicting reports, I'm going to go with the one who is having issues. Because that tells me maybe there's differences in the BT chip in the car...or maybe there's some tolerance issue with manufacturing of the phones. I'm going to put it as one entry and say some people have the phonebook working while others don't. I would appreciate if you could contact the guy who's phone book doesn't work and assist them in getting it to work properly.
  #48
Old 03-09-2008, 04:22 PM
hshields123's Avatar
hshields123
hshields123 is offline
Samsung SCH-U740
Samsung SCH-U740 works.
Phonebook sync, dialing, and call pickup. Not sure about everything else, but the basics are there.
  #49
Old 03-09-2008, 08:43 PM
playtowin's Avatar
playtowin
playtowin is offline
Treo 700w dials, voice dials, call pickup. Phonebook sync does not work. It does not need to be reset every time the car is started (unlike the report on the 700wx).
  #50
Old 03-10-2008, 09:25 AM
Birdman's Avatar
Birdman
Birdman is offline
Gotcha. Also, sent a PM last week to that user, no response. I'm 100% sure all BJ2's works 100% in all r56's.
Quick Reply: Navigation & Audio Bluetooth compatibility list
