Navigation & Audio Anyone Figure Out How to Retrofit The New USB?
Old Mar 3, 2008 | 08:59 AM
  #51
Krut's Avatar
Krut
I'm sure the cable itself is a part... the 2008 models I've seen with the Aux/USB have a cable in a shrinkwrapped bag. It's gotta be out there somewhere. :-)
Old Mar 3, 2008 | 09:15 AM
  #52
rkw's Avatar
rkw
Originally Posted by COOP310
It it was standard and we knew which pin was which, all you would need is an add-a-circuit and a resistior to bring 12V down to 5.
You may want to put in a voltage regulator for protection. I don't know about specifically for MINI, but generally in cars the alternator can cause surges as high as 16V.
On MINI2, UK owners reported that their USB option doesn't include the cable and they have to purchase it separately. It costs them £40 (about $80).
Old Mar 6, 2008 | 10:09 AM
  #53
Kenau78's Avatar
Kenau78
Any mention of a part number from the UK owners. I haven't been able to find on as of yet.
Old Mar 6, 2008 | 10:22 AM
  #54
COOP310's Avatar
COOP310
Try this one: 61120440812.
Old Mar 6, 2008 | 10:46 AM
  #55
nicknbecka's Avatar
nicknbecka
Here's another to try from a Mini2 post:
Quote: Originally Posted by yorkslad (original) Hey Washy, any joy with that part number on your invoice?
Will get it for you:
It is 61 12 0 431 424 ipod cable.
Old Mar 6, 2008 | 11:59 AM
  #56
rkw's Avatar
rkw
I wouldn't buy the iPod cable until you've verified that the USB works with a memory stick. Nobody has demonstrated a successful retrofit yet.
Old Mar 6, 2008 | 08:55 PM
  #57
raz636's Avatar
raz636
For one of the iPod setups, the USB cable goes to the iPod system box then connects to the CAN bus for control and the AUX line for sound input.
Another way they could have done it is with a stand alone USB controller that is controlled by the CAN bus (for MFSW integration) and uses the MOST bus (fiber-optic) for the audio/data transport and additional control.
Old Mar 7, 2008 | 09:10 AM
  #58
Birdman's Avatar
Birdman
You guys seem to be looking for the cable from the back of that "retrofit" usb and aux audio port part, right?
BUT, have you first found where that cable (if found) would plug into?? I would find that first. Reason being, I'd guess you won't have anywher to plug it into. I'd bet there was no USB input on either the bluetooth or stereo head unit for the early models (like mine). Otherwise they would have gave us the usb port in the first place, no?
Just a thought. Hope I'm wrong, would love to add the USB port.
Old Mar 9, 2008 | 06:07 AM
  #59
COOP310's Avatar
COOP310
I got this response from MINIUSA today...
Thanks for contacting MINI. We appreciate your inquiry.
Unfortunately, there is not a retrofit available at this time. I suggest keeping in contact with your MINI dealer for future updates. I'm sorry for any dissatisfaction my answer may cause.
The part about keeping in contact with my MINI dealer leads me to believe one of 2 things.
1. A retrofit is possible, or
2. The CSR has no idea what I am talking about.
Old Mar 10, 2008 | 09:30 AM
  #60
Birdman's Avatar
Birdman
With my experience with MINIUSA, my vote goes to #2. And, I'll add, that was a standard form reply (copy and paste text).
I have found miniusa useless, and non-supportive to the customer.
Old Mar 17, 2008 | 12:41 PM
  #61
jjshoe's Avatar
jjshoe
Does anyone have a full wiring schematic of the 2007 and 2008 mini? this seems like the true place to start.
Old Mar 17, 2008 | 12:53 PM
  #62
jjshoe's Avatar
jjshoe
hrm, if anyone is interested in coughing up the $30 I'd be happy to look
http://www.minitis.com/
Old Mar 17, 2008 | 01:20 PM
  #63
Birdman's Avatar
Birdman
Good luck.
http://www.mcaw.info/wds/mini/us/r56/index.htm
Old Mar 17, 2008 | 02:38 PM
  #64
mikeythemini's Avatar
mikeythemini
Only briefly looked at a Mini with USB
I think the USB goes to the bluetooth module under the left seat
Dont take that as gospel though
Old Mar 18, 2008 | 07:34 AM
  #65
COOP310's Avatar
COOP310
I finally got around to pulling out my aux jack and poking around behind it. So now I can verify that there is no cable back there even for cars with the bluetooth module installed at the factory.
Old Mar 19, 2008 | 01:03 PM
  #66
Kenau78's Avatar
Kenau78
Just wanted ask how easy/hard was it to pull the aux jack. Thanks
Old Mar 23, 2008 | 09:56 AM
  #67
COOP310's Avatar
COOP310
I suppose it depends on the size of your hands. I took off the trim piece next to the aux jack, then fished my hand around trying to unlatch the jack... Cut my hand a little trying to reach the far side, but got it out after a while.
Old Mar 23, 2008 | 02:51 PM
  #68
Mini2na's Avatar
Mini2na
I have lamented that my MINI was produced a few weeks too early to receive the USB..... No, strike that. I have lamented that MINI did not introduce the USB a few weeks earlier.
While looking through the Vendor Announcements I found a USB retrofit kit that works through the antenna leads, displays on the stereo screen, but needs a supplied remote to navigate. They also have an iPod option.
http://www.newministuff.com/new/shop...uctshow&id=403
Not perfect, and with someone actually coming to market with the solution it does not bode well for an easier, integrated solution utilizing plug and play.
Old Feb 28, 2011 | 03:43 PM
  #69
zminicooper's Avatar
zminicooper
I ordered the part today $39.75 + tax from the dealer. I should have it by Monday I will post results.
what dealer did you get it from? The local BMW dealer here in ohio wants 56$
Old Feb 28, 2011 | 03:52 PM
  #70
Nui's Avatar
Nui
Ditto. I had been asking for years and they said Not Available unless we install for $2500
Old Mar 1, 2011 | 05:46 AM
  #71
schatzy62's Avatar
schatzy62
What part are you looking at. If it is the USB connector in the center console only then yes the dealer will want more than $50.00 but you can get it from Pelican Parts or Penske Parts for about $37-$38. If yours i broken then replacing it is not a problem but it you are trying to add USB to a car that does not have that is another story.
Your signature says your car is an 09 MCCS. If that is the car you are trying to add USB to then the if you did not get it from teh factory then the car is not set up for it and the ULF module does not have the proper configuration for this. There is also a wiring harness missing. So to add USB to that car will be in excess of $1000.00
What year is your car? if it is an 2007 then you will have to change the radio unit out and add the proper ULF module. In that case the cost will be in excess of $2000
If the car is an 2008+ then you will need a ULF module see my comments to zminicoooper above.
Old Mar 1, 2011 | 07:34 AM
  #72
Nui's Avatar
Nui
2007 here. Guess we're out of luck. Thanks for the update.
Old Mar 1, 2011 | 07:59 AM
  #73
strobeyprobey's Avatar
strobeyprobey
From the ETK it looks like if your build date is 8/07 you should be able to add the ULF module and the Retrofit kit for the bluetooth. I did the retrofit to my car a couple of months ago and love it!
Old Mar 1, 2011 | 08:02 AM
  #74
strobeyprobey
Here is a link to the retrofit kit. It is valid for build dates between 8/07 and 8/2010. http://www.realoem.com/bmw/showparts...=65&fg=95&hl=2
Old Mar 1, 2011 | 08:47 AM
  #75
Romo.'s Avatar
Romo.
Kit seems pretty reasonable - I'm assuming your car had to be reprogrammed, how much did that cost?
