Navigation & Audio Anyone Figure Out How to Retrofit The New USB?
#26
I'm certain the part will do nothing. USB and BT both require hardware and software to operate. The two functions may very well have been integrated through a chipset or module from the parts supplier. If they were completely independent, it would have been to MINI's advantage to offer them as separate options.
I already have the factory BT module installed, but the 07s did not offer USB in the USA, even though they did in the rest of the world for that MY. My theory of replacing the switch is based on my belief that I can't see MINI going through the expense and added manufacturing complexity when the same thing could be accomplished by simply leaving the switch out and/or disabling it in the SW.
The connection on the back of both the Aux only and Aux+USB "switch" appears to be the same, so it would be a direct replacement using the existing wiring. My theory is that the electronics and software are all present in the BT module and the "switch" is just missing because MINI didn't get FCC approval in time for the 07 launch.
#28
Something to check is how many pins are occupied in that connector (# of wires in the harness). If only 3, they are for the aux only and your harness doesn't include wires for USB.
#29
I thought the same thing about the passenger's side key switch for deactivating the airbag. Still haven't found out where to plug it in. Anyone want to buy my switch and give it a try for themselves, brand new, never been used.....?
#30
http://www.newministuff.com/new/shop...uctshow&id=403
Does this qualify as an option? Just saw this while browsing around their site ... or perhaps it just works on Euro MINIs ... ?
#31
#32
#33
Also looking to add USB
I have 08 with stock radio and aux plug. Took delivery last month and using the aux plug for my MP3 player but would like use MFSW for more that just volume. If the radio is prewired for the USB plug it shouldn't be to hard. Does any one know how to order the USB/AUX plug?
I'd be interested to do this if I knew it would work, but since I just retro-fitted the rear fog lights, I'm a little tired. If you undertake this project, please let us know your experience.
#35
You can order it from Pelican Parts (or probably any BMW/MINI dealer). The part number is: 61319129651.
08MC, Dealer Stock, O2Blue, 6spd manual, Cold Weather Package
#36
I don't have BT but i'm gonna put one in...figure why the hell not. I just did the rear fog light toggle add and have a leftover screw, so I have to take everything back apart to figure out where it goes anyways lol. Worth a shot while I have everything back apart again. I'm contemplating playing dumb and going to the dealer saying my USB port isn't working but it was there when I got it lol...any input for that tactic
#38
#39
If the plug is the same, I can't see them having two completely different head units for the USB or non USB cars...it just doesn't make economic sense...but having it reprogrammed for it to work, that might be the expensive part. I need to have the rear fogs programmed anyways. So maybe i'll save some by having both done at once?
I e-mailed Jayson at Classic Mini and am ordering it from him. I'll do the install and let you guys know what I find out. I called my dealer and they said they would look into it if I just need a reprogram to make the USB port work. So we'll see...
#41
#42
Aux/USB Plug
I picked up the plug today at lunch. It requires two seperate cables, one that plugs into the AUX port and a seperate one that plugs into the USB port. Some how I don't think the USB cable is in the existing Radio wiring harness. I guess I will have to track down the part no. for the USB cable. I will post a picture of the part tonight when I get home.
#43
#46
Aux/USB retro fit
No luck tracking down the cables for the socket. Called the local dealer and they couldn't help. They can find the socket but unable to get part number on the cable. I found a USB Audio retrofit kit on BMW forum, Retrofit kit No. 65 41 0 443 678 USB/audio interface retrofit kit, but none of the websites or my dealer parts department show the part. If anybody has any ideas let me know. My local dealer is going to do some research and see if it is listed in any of their update bulletins.
#47
#48
Is the USB interface on the back of the box a standard interface type? Do you have a better photo?
Worst case scenario, you could find out what pins are for charging and connect it to power to charge your USB accessories. iPod, RAZR, etc. It may not be as cool as the full functionality, but still a neat mod!
#50
It it was standard and we knew which pin was which, all you would need is an add-a-circuit and a resistior to bring 12V down to 5. (and an old phone to test it on so you didn't blow up your nifty new one.)
I'm still looking for the full retrofit though.
