Navigation & Audio Parrot Bluetooth wiring to the Hi-Fi amp?
Old Nov 4, 2007 | 05:54 AM
Bor's Avatar
Bor
Given the access to the stock radio unit is difficult/scary/impossible - wouldn't it be easier to wire the Parrot Bluetooth handsfree setup to the HiFi amp in the boot ? Any idea which wires go to where please ? Any idea if/how the audio quality will suffer?
9switchbox) to the HiFi
Old Nov 7, 2007 | 09:25 AM
Bor's Avatar
Bor
OK, let's try it different way - anybody has a wiring diagram for the HiFi amp and maybe links to somebody who sells the compatible connectors/plugs please ?
Old Nov 7, 2007 | 10:19 AM
pdoyle's Avatar
pdoyle
Do a search here in this forum. Those wiring diagrams have been posted here before. It may be in this thread.
Old Nov 9, 2007 | 09:21 PM
raz636's Avatar
raz636
Buy the Parrot Harness
Just buy the wiring harness for the car. Go to www.parrotkits.com
Getting behind the stock stereo isn't that hard; it just take some time.
Old Nov 13, 2007 | 09:36 AM
Sensor's Avatar
Sensor
Does that harness allow you to use the MFSW?
Old Nov 13, 2007 | 11:56 AM
TheOfficeMaven's Avatar
TheOfficeMaven
Is the parrot harness plug-n-play like the ones available from NewMiniStuff.com or do you have to actually hack into your car's wiring to install it (which is never a good thing IMHO)?
Old Nov 13, 2007 | 08:07 PM
raz636's Avatar
raz636
Harness Desc.
The Parrot harness($54.95) was designed to work with the OEM connectors in the mini and the ISO connectors on the Parrot Bluetooth kits. There is no wire splicing; it's just plug-and-play.
The harness itself does not integrate the MFSW. You need to purchase the Parrot MultiCAN ($98.14) unit to have the CK3000 or CK3100. The MultiCAN connects to the harness and the Bluetooth unit. If you have microcontroller skills, you can easily design a system that reads the CAN bus signals from the MFSW then sends them to the Parrot kit.
Filmy
15
Jun 6, 2023 06:27 AM
Filmy
Apr 28, 2019 11:37 AM
Filmy
Sep 7, 2015 08:27 PM
Filmy
Sep 7, 2015 11:27 AM
