Navigation & Audio Aux Input installed! (pics)
Old Nov 7, 2004 | 08:33 AM
  #76
moonman9j9's Avatar
moonman9j9
I'm wondering if I can fashion my own Aux. input. I'm certain I can get the 1/8" jack connector from Radio Shack. The connector for the back of the head unit might be a different story. I have the non-HK unit with no NAV, so I'll just have a blank spot there, correct? I wonder if I can pick up a connector from the dealership.
Old Nov 7, 2004 | 06:17 PM
  #77
rcase13's Avatar
rcase13
Be careful I believe there are some electronics involved. Can't be too complicated. Do a search as this has been discussed before.
Old Nov 7, 2004 | 08:28 PM
  #78
moonman9j9's Avatar
moonman9j9
I searched but came up with nothing.
Old Nov 8, 2004 | 04:34 AM
  #79
rcase13's Avatar
rcase13
Here is a link that indicates the prescence of a circuit board:
https://www.northamericanmotoring.co...05&postcount=2
The Aux input is so cheap to buy that most deemed in not necessary to try and duplicate.
Old Nov 8, 2004 | 04:46 AM
  #80
moonman9j9's Avatar
moonman9j9
*sigh*
Fiiiiiiiine I'll shell out the $40 for a friggin wire.
Old Nov 8, 2004 | 05:06 AM
  #81
Aqualung's Avatar
Aqualung
more info over at MINI2..http://www.mini2.com/forum/showthrea...+loop+isolator
seems that w/ the homemade version, most folks also put in a ground loop isolator.
Old Nov 8, 2004 | 07:07 AM
  #82
moonman9j9's Avatar
moonman9j9
Thanks a billion for that link! I searched extensively for something like that to no avail. I have the necessary computer cables lying around my bedroom to make this work. Thanks!
Old Nov 9, 2004 | 11:20 AM
  #83
moonman9j9's Avatar
moonman9j9
It didn't work. I made the cable perfectly but the head unit didn't recognize the input at all.
I paid the $40 at Vista Mini and bought the friggin cable.
Old Nov 11, 2004 | 04:13 PM
  #84
Smokey's Avatar
Smokey
Is it working with the OEM cable?
Hope your car is an 03 or newer, the 02's headunit won't work with the aux.
I finally broke down and picked up and installed an 03 unit to do away with the FM Modulator.
Old Nov 16, 2004 | 11:13 AM
  #85
moonman9j9's Avatar
moonman9j9
Yes, it's working with the stupid OEM cable.
I would have been MUCH happier if my custom one had worked, especially since I took the time to make it myself.
Old Nov 16, 2004 | 11:36 AM
  #86
911RSAmerica's Avatar
911RSAmerica
Originally Posted by mini-rolls
Here is the location of my AUX port.
You missing a peddle!
Old Jun 8, 2006 | 03:14 PM
  #87
acitydweller's Avatar
acitydweller
this soiunds like an awesome write up. Just i wished the photos were still around.
Old Jun 24, 2006 | 11:15 AM
  #88
Kellonwheels's Avatar
Kellonwheels
I 2nd that! Greatbear - Any chance of seeing those pics?
Old Jul 1, 2006 | 09:13 AM
  #89
acitydweller
i am doign the install.. i need pics!!!
Old Jul 29, 2006 | 09:52 AM
  #90
Doc C's Avatar
Doc C
Lost Aux!!!!
I have tried to find the answer to this and it must be very simple. I have an '05 MCS with H/K stereo and no nav. I had the AUX input installed at dealership before purchase. All this time when I pushed the MODE button it would scroll through AUX,FM1 etc..... I had a shop put in an XM radio and run it through the AUX input. The shop says it worked great for them. It never has for me. Now when I push the MODE button it goes throught everything, but does not have an "AUX" option!!!!! I did this so I wouldn't have to FM modulate my XM. What happened that the radio will now not have an AUX option??? Please help. I'm sorry if this is a dumb question, but I have spent 1.5 hours pushing buttons and reading owner's manual. Thanks in advance!!!
Old Jul 29, 2006 | 10:06 AM
  #91
rkw's Avatar
rkw
Doc C, this is a common problem and you probably need to add a ground loop isolator. Enter a forum search on "ground loop isolator" for lots of information.
Old Jul 29, 2006 | 10:09 AM
  #92
Doc C's Avatar
Doc C
rkw,
Thanks man. I found that info right after I made this post. I'm sorry about that. Thanks for the info. Great forum!!!
Chris
Old Oct 4, 2006 | 06:59 AM
  #93
aznqtboy984's Avatar
aznqtboy984
I just bought the cable and doing this for my car soon. Pictures would be nice.
Old Oct 4, 2006 | 07:06 AM
  #94
Bosevii501's Avatar
Bosevii501
Follow this link: http://www.mini2.com/forum/faq.php?f..._faq_aux_input
Sometimes you have to scroll down the page to the section on aux input.
Old Oct 11, 2006 | 04:07 PM
  #95
KnottyMan's Avatar
KnottyMan
Another request for GB to repost the pics somewhere. I've got the ipod, got the NAV, got the non HK head. Don't got the pictures to make AUX work. (still need to get the cable)
Old Oct 12, 2006 | 07:12 AM
  #96
PiercedMini's Avatar
PiercedMini
It is so easy that it should just come standard. I put mine in last night and it took a whole ten minutes including drilling the three holes. Works great but has anyone else noticed that the radio doesn't go as loud with the Aux setting?
And for anyone thinking they need pic's just pull your knee board down below the steering wheel, feel right behind the radio on the side closest to the steering wheel. Plug the plug into that space and drop the cord down behind the radio and pull it through by the cup holders. Mount the plug where ever you want and your done. Push the knee board back up, and listen to your music.
Old Oct 12, 2006 | 08:25 AM
  #97
KnottyMan's Avatar
KnottyMan
The NAV audio uses the existing AUX input socket. However, there are extra pins that can still be used for AUX audio. GreatBear figured it out and posted pics but they are not there anymore. I could disconnect the NAV audio, especially since I can't get the GB voice on my mk3, but it would be nice to have both as an available option.
Old Oct 12, 2006 | 10:22 AM
  #98
Smokey's Avatar
Smokey
Depending on what you are plugging into your aux, who should be able to tweak the input volume. The Roady's all have that function in their menu
Also the standard car radio has a aux input adjustment. On the left side of the face, there is a button with a "Note" symbol on it. Pressing that will cycle through the adjustable options available, the last one is Aux (I think). Once there turn the volume **** and that adjust the level either up or down, I think the max is 5.
Old Oct 12, 2006 | 11:41 AM
  #99
PiercedMini
Thank you very much. I will give that a try when i get out in the car.
Old Oct 12, 2006 | 02:41 PM
  #100
PiercedMini
Smokey thanks that worked like a charm. The Aux level was set at 0. I was a little confused why i never noticed that the stereo only went so high before. Now it cranks again.
