Navigation & Audio Front door speakers- components or a 6.5" and a 3.5"?
Old Sep 5, 2007 | 07:16 PM
jimsevo8's Avatar
jimsevo8
Hello All,
Here's my dilemma:
I have the stock boost system (non-Hi-Fi). I want to upgrade the audio system and I am starting with the speakers. The 3 component Focals are nice, but out of my budget, so I need some opinions:
1. Get a set of 6.5" component speakers and put the tweeter where the 3.5" stock speaker is.
or:
2. Get a 6.5" two-way and a 3.5" two-way and just put them in the factory spots.
This is my first step in upgrades, later on I plan to add an amplifier with a sound processor, so I can retain the stock head unit.
If I go with the stock style set up of the 6.5 and 3.5 can I wire it up in such a way to power all 6 speakers from a 4-channel amp? Say, if the 2 in the doors are both 4 ohm and wired in parallel (and I get a 2-ohm stable amp)?
I'm not going to do a sub because I intend to autocross the car and don't want too much weight added.
Thanks in advance.
Old Sep 5, 2007 | 07:27 PM
MotorMouth's Avatar
MotorMouth
I'd go with a good quality 2-way component set. Mount the tweeter where the 3.5" goes. Lots of choices for 2-way components. Or you could buy the a-pillars for the tweeters from your dealer and get a 3 way.
Old Sep 6, 2007 | 12:20 PM
Straius's Avatar
Straius
How difficult is it to install those a-pillars?
I was thinking about mounting the tweeters in the 3.5 spot as well but wasn't sure if I wanted to make my own mounting "adapter" to fit the smaller tweeter in there. seemed like it would kind of be a hack and slice type of job.
Old Sep 6, 2007 | 12:37 PM
MotorMouth's Avatar
MotorMouth
pretty easy to swap out the A pillars. Certainly no harder than pulling them off to change the tweeters.
boostedhaze
Jan 2, 2018 07:26 PM
Powershift
Aug 16, 2015 05:14 PM
FLYM1N1
Aug 15, 2015 11:20 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
