Navigation & Audio USB Audio Port In 2007 MINIs
I thought that when an iPod was put into "Enable Disc Use" mode it exposed the free disk space on its drive as a MSD (Mass Storage Device), but that it didn't expose any of the songs/playlists it contains (since they are stored in a proprietary database format designed by Apple to prevent folks from easily sharing the songs on their iPods). I guess that you could also set up additional songs in the MSD area, but that seems kind of silly since you can't take advantage of the actual iTunes/iPod stuff that way. Isn't Apple just wonderful.
Never owned an iPod, was unaware that in "Enable Disc Mode" it just pro-offered the free space only?
Anyway, I saw this posted on mini2, from from MINI corporate communications (?), and it states that iPods can be connected and the music played via the audio system via the USB. But, it could be like you said - your own files on the iPod in the free space made available by enable disc mode? Eeek.
http://www.mini2.com/2007/05/25/incr...del-year-2008/
and to quote: "For even simpler extension of on-board entertainment facilities in the new MINI, a USB connection including Bluetooth function is optionally available from August 2007 for the integration of external audio sources. This enables USB-compatible storage media and MP3 players such as the Apple iPod to be integrated in the MINI entertainment system via the USB port. Music selection can then be accessed via the audio system controls where the menu offers to choose between interpreter, album etc."
With an ipod "enable disc use" only lets you transfer data (photos, files) from the disc to another computer. You cannot see the data on the iPod screen. You cannot play music using this method. The music must be in the ipod's library along with the tags, covers, etc, just like the photos you can view, which are formatted for the ipod using iTunes. Sounds like this usb port will be pretty useless unless the software in the car allows integration, as iTunes does. Maybe it will charge it, but I don't see how unless it's plugged into a 12v power port.
It also states:
"** Please note, this is an international (Germany and Netherlands to name two) press release, so is not entirely market specific, there may be some regional variations on spec **"
As we already know, the start stop and diesel aren't coming here, so many not the USB on all of them either.
What I think is that any .mp3 file on the iPod should be accessable over the USB connection. However, if it was stored by iTunes it will be in a seemingly random folder and won't have a recognizable file name. For access and organization, you'd want to manually copy mp3 files yourself to the iPod storage and into folders that you create.
What I think is that any .mp3 file on the iPod should be accessible over the USB connection. However, if it was stored by iTunes it will be in a seemingly random folder and won't have a recognizable file name. For access and organization, you'd want to manually copy mp3 files yourself to the iPod storage and into folders that you create.
My guess is that if the HU supports iPods through USB, it seems to me that it would be the same as the iPod adapter interface. If that is true, then the software would have to be smart enough to know when an iPod is attached vs a thumb drive or other mp3 player and handle the devices accordingly. Of course, being a programmer, I may be over-thinking this a bit!
I went back and forth on ordering the Ipod adapter with my car. Since I don't own one now, I would purchase one just to use in the car. If my Aug 07 built car does come with the USB port as a bonus, this will nullify the need for an ipod!
I'm the same way - music nut, but not an iPod owner (Archos)- and my JULY build may have just missed out on the USB. So I'm still back and forth on the iPod adapter....But, I may get the iPod adapter anyway. As I need a new mp3 player, and a GPS unit, and I am interested in the cool OBDII display units, I'm thinking of getting all that stuff into one device and streaming the music off it over Bluetooth to a receiver plugged into the iPod adapter, and still controlling it via the steering wheel. Not sure if I can get the artist/track to display on the radio. Should be able to put this together for less than the cost of the NAV unit, but with a hell of a lot more functionality! Still researching it all, to make sure it will actually all work!
Here's the answer on MINI2 concerning iPod connection to USB: http://www.mini2.com/forum/2nd-gen-i...ction-how.html
You need to purchase this cable from BMW:
It appears that the USB controls and charges the iPod, and the audio goes in through the aux port. It integrates with Nav, and presumably with the headunit if without Nav.
RKW brings the Goods. But Is There Any More Info..
rkw - you did it.. that what we are looking for on this forum.
Two one more questions to anyone out there... still a little confused.
1/ can you show a picture of the connection (plugged into USB)
2/ what week was this build made??
Thanks once again..
Thanks once again..
We also need a part number and we need to know if it's even available in the U.S. (since the USB port itself isn't as of yet).
Figures that you have to use yet another adapter in order to get the built-in USB port working with an iPod. Just one more instance of BMW/Apple trying to rape us of every single penny we have. Oy!
EDIT:
@mikeyjaro,
EUROKOKE's MINI (i.e. the only US-spec MINI to have the USB port thus far) was a week 32 build. However, we have conformation of other week 32 builds that don't have it (even when they have the required Bluetooth prep package).
EDIT:
@mikeyjaro,
BMW USB/iPod Adaptor
- Here's the link on the BMW US website (nothing for me here in Canada)
http://www.bmwusa.com/BMW2003/Templa...ACHEHINT=Guest
Better to ask this on MINI2, where they have actually done it. However, it's easy to imagine. Look at the picture of the cable package, at diagram #2 inside. It shows plugging in the USB and aux cables, and the iPod goes on the dock connector at the other end. I guess they meant the iPod to sit in the cubby under the toggle switches.
will do when i get home.. need to work
The USB port makes a lot more sense now! You get most of the benefits of the iPod adapter without the extra expense! You just lose the ability to tuck it away out of sight.
It would have to if you are able to use the MFSW to control the iPod. Good question about the Nav though.
To each their own..
We all have our wants.. don't dis' ours chirping BirdDude.
Hey, what's the matter with Queen? Besides, whoever took that photo chose it for the title of the song.
The photos came from a Mini2 thread and since it's a British band, I can understand. You will notice the glovebox release button on the left side of the nav screen.
Wasn't it a $400(or was it 500?) add on?
