Navigation & Audio My Nuvi 660 GPS, Kuda mounted and hardwired
Old Nov 16, 2008 | 12:01 PM
  #76
foxy1's Avatar
foxy1
are these kuda mounts available for the R56's in the UK? right hand drive.
Old Nov 19, 2008 | 09:06 AM
  #77
SPF ZERO's Avatar
SPF ZERO
The Kuda mounts are not directional, they go over the "hump" in the middle of the dash. I know that for my R52 cabrio it could work for left or right - I'd assume it would be the same with the R56 generation. I had a great experience with buying from Kuda and quick response when I asked them questions. Here's their website: http://www.kudausa.com/
I just noticed they have a UK website as well, but it looks to be all about truck accessories.
Old Nov 19, 2008 | 09:40 AM
  #78
ScottRiqui's Avatar
ScottRiqui
Actually, on my R52, I tried mounting the Kuda mount to the right of the "hump" just for grins, and it didn't fit. The Kuda mount follows the contours of the dash edge very closely, so it only fits tightly when installed on the left side of the hump.
On the right side of the hump, the dash edge is slanted the other way (down and to the right instead of up and to the right), so the cutouts in the Kuda mount won't follow the edge of the dash. You might get it to fit, but there will be gaps between the mount and the dash, and it likely won't be as rigid as it would if you mounted it on the left side of the hump.
Old Dec 2, 2008 | 08:07 PM
  #79
NJP's Avatar
NJP
Originally Posted by lacning74
So I went to take pictures of my installation, and looks like my Mini has an admirer. This better not be the one that left a permanent bird crap stain on my bonnet.
Bird has good taste!
Old Dec 13, 2008 | 02:31 PM
  #80
jbewley's Avatar
jbewley
Originally Posted by celica414
I'm trying to figure out where you ran the wires, can you draw a red line on my pics showing what you did....that would be very helpful!
Celica. it looks like you removed the driver's dash trim and the speedo cover/vent covers leaving all the other things in place. I have my power wire behind the dash trim and following the groove on the right between the vent cover and the speedo. I would like to get in behind the vent cover for a cleaner job. Other then the two screws under the dash vent at the top of the speedo how many other screws did you have to remove to get the speedo/vet covers off?
Jim
Old Dec 16, 2008 | 09:51 AM
  #81
jbewley's Avatar
jbewley
Originally Posted by ekailee
I ordered 92445 (Side Mount) and should have ordered 292445, the top mount. http://www.kudausa.com/kuda_mount_an...07-34-529.html
I just went to the Kuda site to order the side mount which I want to use for my cell phone. I clicked that in the divice group and it said I did not need an add on. Does it come with that holder?
Jim
Old Dec 27, 2008 | 08:13 AM
  #82
jbewley's Avatar
jbewley
Now that the shock is over, here are pics of my installation.
Kuda mount:
Fusebox with Add-A-Circuit (WARNING! Check instructions later in thread regarding which way to put it in.):
Fuse box and lighter socket:
Tucked away:
I followed all your instructions and all went well until I tried to find a ground. Everything under that dash is plastic and I can not find a metal to metal ground point anywhare. I am going from the fuse box directly under the passanger foot well. Any ideas??
Jim
Old Dec 27, 2008 | 09:30 AM
  #83
mitemini's Avatar
mitemini
I grounded mine on the top right screw that holds the fuse box to the body. Worked fine so far at 3000 miles. Its kind of hard to get too but can be done.
Old Dec 27, 2008 | 10:39 AM
  #84
NJP's Avatar
NJP
The Garmin installation (which I use also) reminds me of last week when I used the GPS. When I got home I "gently" pulled the DC power from the outlet & the entire outlet came out! Have to go back to the dealer for something else so they can fix it then, but, why would the dc outlet come out? Don't they attach them to something down under???
Old Dec 27, 2008 | 01:50 PM
  #85
jbewley's Avatar
jbewley
Thank you. It can't be any harder to get to then everything else is. I'll give it a try in the AM.
Jim
Old Dec 27, 2008 | 06:57 PM
  #86
lacning74's Avatar
lacning74
Jim
i think i mentioned it somewhere in this thread. i used the screw to the left of the glovebox seen when opened. anyway, good luck with everything!
Old Dec 27, 2008 | 08:37 PM
  #87
pilotart's Avatar
pilotart
Jim
If you have a Soldering Gun (100W was plenty)
I soldered my ground to the sheet metal seen inside in upper forward corner:
This was very easily done and I am confident of a 'good' ground.
I also fished the wires inside, entirely behind the side panel.
Old Dec 27, 2008 | 08:49 PM
  #88
lacning74's Avatar
lacning74
i've been looking for an easily accessible cleaner "ground" especially now that i have my carpc setup. i'm going to try that piece of metal. thanks. yeah, i should take new pictures of my tucked away wiring, but i do have it running behind that trim piece.
Old Dec 27, 2008 | 09:23 PM
  #89
toolazyforalogin's Avatar
toolazyforalogin
What fuse # are you guys using? ..just curious....I don't think I used that one - I'll have to check tomorrow.
Old Dec 27, 2008 | 09:38 PM
  #90
lacning74's Avatar
lacning74
i used f21 in my original install. it powers on when the door is unlocked and stays on for 30 minutes after the ignition turns off. i thought it might be cool for the nuvi to be powering up and locating satellites while i walked towards my car after hitting my keyfob remote. stupid idea, because leaving the nav visible will get it stolen and it won't turn off automatically when the engineis shut down. most people use something like f32, an ignition switched fuse,m which is what i definitely recommend for a portable nav, radar detectors, and such. portable sat radio users might want to use something like f21 so when the ignition is turned off they can still hear the music and use it.
right now i'm usiing f32 to power up my radar detector and carpc and f21 for a timer relay that's soldered to the power switch of my carpc.
Old Dec 28, 2008 | 10:57 AM
  #91
wannab drivin's Avatar
wannab drivin
I just got a Nuvi 755T for Christmas. I've downloaded the SRF Mini car files from the link I found here on NAM to my computer, but how do I get them uploaded onto the Nuvi?
Sorry if this is a dumb question!
Old Dec 28, 2008 | 12:17 PM
  #92
TheBigNewt's Avatar
TheBigNewt
I got a TomTom 125 and I want to do the same thing. Anybody have an idea?
Old Dec 28, 2008 | 02:12 PM
  #93
MiniIvan's Avatar
MiniIvan
While my original Kuda mount location was perfect in terms of visibility while keeping you eyes on the road and in terms of an easy finger's reach, I couldn't resist trying a new location. I just double-sided taped the Garmin adaptor mount to the dash piece. More pictures in this thread.
It's not as easy to control with my left hand, nor is it as easy to see, but I like it's more stealth location for now. I also just received the new nav audio stereo interface form newministuff. I'll update y'all on the install. I'm actually looking forward to taking apart the dash again and removing the stereo. It definitely gets easier and more fun every time I do it. That goes for all my installs.
After many hours of trying to find the perfect spot for my Garmin 265wt, I came up with the same solution using the adhesive plate that came with it. As you said, it's not as easy to use with the left hand, but it doesn't block my view of anything and it's much more stealth.
Old Dec 28, 2008 | 02:32 PM
  #94
jbewley's Avatar
jbewley
Project is now complete and I owe a large thanks to all here for their assistance. As was said here before "there is more then one way to skin a cat" so I will re-cap the approach I took to add to the others.
First let me agree with Lancing74 that with the PartsExpress lighter plug the ribbed wire is power and the other ground.
I located the metal plate mentioned by Pilotart and drilled a hole in it inserting a small screw. I then crimped a "U" shaped connector on the ground wire, inserted it and tightened it down. I then added the Add-A-Circuit to F32 (facing forward by the way) and all worked first try.
I ran the wires from behind the panel with the fuse box, under the top of the passanger side floor mat and behind the center stack to the driver's foot well. I ran the power cord up through the MFSW opening and followed the same route as Lancing74 to the Garmin. The other end I dropped down into the driver's foot well, pluged it in and stuffed everything up behind the center stack. This seemed like the shortest route.
Thanks again for all the help.
Jim
Old Feb 14, 2009 | 12:32 AM
  #95
mataku's Avatar
mataku
I really love the write-ups and how to's, it really helps those of us who are really new to all this succeed without great failure. One question on which fuse to use though, does either of those fuse locations provide power during start up? I ask because I'm thinking of getting a Pioneer AVIC-F500BT since they are so cheap now and they are known to have problems when the power cuts off during start up.
any help is appreciated.
Old Feb 14, 2009 | 06:11 AM
  #96
jbewley's Avatar
jbewley
The first location (shown in the picture) did not work for me. I then tried F32 (third row) and all is just fine. In the third row it plugs in opposite to what is shown for the center row which somebody mentioned elsewhere in this thread.
Good luck,
Jim
Jim
Old Feb 14, 2009 | 06:26 AM
  #97
lacning74's Avatar
lacning74
Good luck,
Jim
Jim
yeah f32 is ignition triggered. i had originally used f21 as in the picture which turns on when you unlock the doors and stays on after you shut the engine for 30 minutes like the radio. i now use F21 just to trigger my carpc to startup. F32 to power my accessories. the "hot or not" post in the electrical forums lists em all and what they do.
Old Mar 7, 2009 | 05:20 PM
  #98
alalo's Avatar
alalo
Thanks!
Hey guys, just a quick note to say thanks. These are great instructions!
I just finished installing my and nothing got fried and every works.
Old Mar 7, 2009 | 07:33 PM
  #99
jbewley's Avatar
jbewley
Good job. I like it when a planm comes togeather.
Jim
Old Aug 30, 2009 | 09:03 AM
  #100
bezwi's Avatar
bezwi
For Europe check out http://www.kuda-phonebase.de/start.php
sorry only a phone mount at the moment.
