MTH Discussion (Archive) Have or interested in MTH software upgrades for your MINI? This is the place! Sponsored by MTH.
Is this the...correct cable for MTH?
Old Feb 20, 2006 | 12:59 PM
Minirowski's Avatar
Minirowski
Old Feb 20, 2006 | 01:44 PM
Martin@Sensolutions.com's Avatar
Certainly is ...
Yes this cable is the one you need for a USB connection.
Sensolutions
Old Feb 23, 2006 | 03:18 PM
FUEGO's Avatar
FUEGO
And it works great. Its a whole lot faster than my first serial MTH cable (with a huge 'bump' in the middle) I purchased from overseas over a year ago. This cable gets
Old Mar 14, 2006 | 09:21 AM
cheesyman's Avatar
cheesyman
with regards to the cable, does anyone knows if the USB or the COM version works better? thanks.
Old Mar 14, 2006 | 09:29 AM
The MINITOR's Avatar
The MINITOR
Should work the same if you have both ports as far as I know. The COM is supposedly easier to setup and can be extended cheaply and without loss of signal, whereas the USB is more expensive and less able to be extended in length (if you arent using a laptop). Many newer PCs dont have COM ports though.
Old Mar 14, 2006 | 10:18 AM
SumWon's Avatar
SumWon
That is correct. I have used both (on the same machine but not at the same time ) with success.
Old Mar 15, 2006 | 03:31 AM
cheesyman's Avatar
cheesyman
Thanks for the input/guidance, mate. Anyway, I just realize my IBM laptop does not have the serial/com port ....
minimofo
Dec 26, 2015 12:03 PM
rikaro
Nov 24, 2015 02:05 PM
ahorvath
Oct 3, 2015 01:13 AM
MINI Stupor
Oct 1, 2015 11:36 AM
Emnotek
Sep 29, 2015 07:37 AM
