MTH Discussion (Archive) Have or interested in MTH software upgrades for your MINI? This is the place! Sponsored by MTH.
MTH Questions
Old Sep 23, 2005 | 01:46 PM
Paul Webster's Avatar
Paul Webster
MTH Questions
Can you remove the timing going to 49deg when I change gear?
Can you lock the timing out at any degrees I want from 3000rpm onwards??
Can you put the rpm limiter at any rpm I want as an example 7700rpm??
Do you adjust the afr, and if you do can you set it at what you like??
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
twriter
Oct 2, 2015 03:14 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
