Mini/MINI BUILDS Showcase your Build Talents.
K24 swap into R53
Old Sep 11, 2018 | 05:02 AM
  #51
Kr4nG's Avatar
Kr4nG
Originally Posted by IQRaceworks
What about the power windows, gauge lights, interior lights, headlight/tail lights, blinkers, radio, etc, etc,......does all of that stuff work?
The ECU in our mini only control the motor and communicate with the body control module. My mini ecu is completely out of the car. My reverse lights work too. Answer is yes. It all works like nothing happened.
Old Sep 11, 2018 | 05:39 AM
  #52
IQRaceworks's Avatar
IQRaceworks
Can you give me some more info on the kpro software? How easy is it to program/tune the motor with it? Is it similar to megasquirt type software?
I'm assuming it works with the Acura pcm?
Thanks!
Old Sep 11, 2018 | 05:46 AM
  #53
Kr4nG's Avatar
Kr4nG
https://www.hondata.com/?_route_=kpro Im using 02-04 rsx type s engine harness with 02-04 kpro ecu. it has its own wiring and does not communicate with the mini at all. you need 3 wires. constant 12v, ignition, and fuel pump wire. Then fan control but that another situation. Im also using the k-tuned swap harness (any chassis kit) its all plug and play at that point.
Old Sep 11, 2018 | 07:27 AM
  #54
MINI33342's Avatar
MINI33342
I see some excitement in your future...........
Old Sep 11, 2018 | 07:28 AM
  #55
Kr4nG's Avatar
Kr4nG
that was rude... what was your point.
Old Sep 11, 2018 | 09:50 AM
  #56
squawSkiBum's Avatar
squawSkiBum
Moderator
my thoughts exactly.
Old Sep 12, 2018 | 08:27 AM
  #57
Kr4nG's Avatar
Kr4nG
Fan control is complete. Very small task but a huge deal for me to find the correct wire. Whats happening is when its time for the ecu to turn on the fan it checks the Engine Coolant Temp Sensor that is on the head. In the software I can turn the fan on at whatever temp I want. From the conversion harness I have 1 FANC wire. That wire is actually a ground signal produced by the ecu. In the original mini harness I have found the FANC wire and tested it by simply touching it to a chassis ground. After various of tests I connected the Honda FANC wire to the MINI ecu plug.
This is the wire I found that kicks on 1 relay in the engine bay. Ground that and you have Fan on. Im using original connector in the engine bay spliced to my new fan.
screenshot of K-Manager. So much can be done with Hondata. Its pretty much a stand alone ecu.
Old Sep 12, 2018 | 11:24 AM
  #58
bryyando's Avatar
bryyando
badass. jaw - - - - > floor
Old Sep 28, 2018 | 10:55 AM
  #59
Kr4nG's Avatar
Kr4nG
I believe this will be the final update for you guys. I still need to get it tuned its running a stock basemap for now. Motor is stock anyway besides intake manifold, throttle body and exhaust. So the car runs great. Their are no engine lights and it runs as it should.
As for the cluster goes, for now I use my phone. But I do want the CD7 dash from AEM but its just not priority right now.
I put the exhaust shield on with some minor trimming and bracket need to be made.
I have also put back the bottom splash shield. No trimming fits like stock.
Old Sep 29, 2018 | 05:39 AM
  #60
dmcgroggan3's Avatar
dmcgroggan3
Love how oem this looks for someone who does not know a mini.
Excellent work
Old Sep 29, 2018 | 09:36 AM
  #61
bee1000n's Avatar
bee1000n
The first post in this thread was only 3 months ago! Congratulations! Hope you have lots of great miles ahead.
Old Sep 29, 2018 | 12:57 PM
  #62
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
Kr4nG made the swap look easy, maybe some of those R50's with blown transmissions will get back on the road, I know I've been looking for one.
I gotta have AC though
Old Sep 29, 2018 | 01:17 PM
  #63
Kr4nG's Avatar
Kr4nG
Thank you all for the nice comments. I hope other people will start doing this swap as it will open another world for our minis.
Old Sep 29, 2018 | 01:25 PM
  #64
MrBlah's Avatar
MrBlah
Kr4nG you have part numbers for parts you used, like the motor mounts?
Old Sep 29, 2018 | 01:33 PM
  #65
Kr4nG's Avatar
Kr4nG
No part numbers. As you can see in the previous post. I bought the integra/civic kits and turned those mounts into the ones that I needed for it to work for my car. Custom made. Someone needs to 3d scan my mounts and start selling them as a kit.
Old Sep 30, 2018 | 03:15 PM
  #66
MrBlah's Avatar
MrBlah
yes they do! Do you think there is room to run a supercharger, or are you going to run a turbo?
Old Oct 1, 2018 | 05:52 AM
  #67
Kr4nG's Avatar
Kr4nG
I believe theirs room for both
Old Oct 25, 2018 | 03:45 AM
  #68
MrMicL's Avatar
MrMicL
I know a guy, and it seems like you took some amazing photos as it is... this might be a thing
Old Oct 25, 2018 | 07:38 AM
  #69
JKo's Avatar
JKo
Incredible job. And in such a short time too. It took me almost a month to swap the head on mine... (well, there were some unexpected issues, but still)
Looking at the engine bay pics it looks like there's easily room for a V6...
Old Oct 25, 2018 | 11:53 PM
  #70
StingWay's Avatar
StingWay
If kits are made, I will seriously consider this.
I just really want to make sure the rest of the car inside has an OEM look, that would be the biggest headache for me haha, making sure all OEM clusters and lights work.
Old Oct 26, 2018 | 04:39 AM
  #71
Bnourai's Avatar
Bnourai
Wow, what an awsom job, it looks great,and I am sure lots of power to boot.
Ben
Old Nov 13, 2018 | 03:49 PM
  #72
Kr4nG's Avatar
Kr4nG
I have completed my return fuel system. It wasn't too hard. The mini fuel pump-hat has an existing nipple that is capped off. I have cut the tip of it and used the evap quick disconnect fitting that is then connected into a -4an return hose all the way up to the engine bay. Under the pump-hat I also added another hose that drains to the bottom of the tank. This way no splashing will happen inside. (not pictured.)
Factory Clips were still used. The 2 evap lines were cut out and thrown away.
Old Nov 14, 2018 | 04:41 PM
  #73
PEneoark's Avatar
PEneoark
This is freaking impressive
Old Jan 27, 2019 | 06:45 PM
  #74
Kr4nG's Avatar
Kr4nG
I put my NAV screen to good use. I can do screen mirroring and I have a HDMI and Composite connector. Now I can see my data on the screen.
Old Jan 27, 2019 | 07:47 PM
  #75
yesti's Avatar
yesti
That is awesome-sauce
