Mini/MINI BUILDS Showcase your Build Talents.
K24 swap into R53
Old Jul 14, 2018 | 09:35 AM
  #26
dmcgroggan3's Avatar
dmcgroggan3
Amazing build bud..... You are all man hands!
Any thoughs on what may be more engine weight to the right of the car and how to compensate for balancing?
Old Jul 14, 2018 | 09:42 AM
  #27
Kr4nG's Avatar
Kr4nG
If you think about it the engine and trans is in the same side as it was before. And now that this engine is lighter, it will just help the overall weight. The weight change isnt my concern at all.
Old Jul 21, 2018 | 06:51 PM
  #28
Kr4nG's Avatar
Kr4nG
I have completed the shifter box and the cables. I also did the clutch line and bled the system. I have completed the exhaust manifold and cat converter with flex pipe. The header needs a bit more touch up and another o2 bung welded. Enjoy.
Honda hard line into mini hard line.
Little trimming needed, not much.
Fits like oem. Even used the oem holes and bolts to mount it into the same spot.
K-tuned no cut shifter box. All aluminum and it has a cover for the bottom which makes it fully enclosed. The stock heat shield fits right under it like oem mini.
3 inch flex into 2.5 inch v band with 3 inch high flow cat. and another v band clamp
The header needed to be bent up at the runners then down at the end. I have to grind and paint the rest of it.
Next will be the radiator and condensor. Once that is in place I can finish the 3rd mount.
Old Jul 22, 2018 | 05:13 AM
  #29
Bnourai's Avatar
Bnourai
Great job bud.
Old Jul 22, 2018 | 07:39 AM
  #30
BoostedBlueToyotas's Avatar
BoostedBlueToyotas
Nice work.
Old Jul 27, 2018 | 05:17 PM
  #31
Kr4nG's Avatar
Kr4nG
Here is some more progress. Next week will be the first attempt to start it up.
Clearance is perfect.
I need the first 02 sensor and the 90 bung might get plugged.
Front Radiator clearance against the block. I wont be able to use the front mount as my 3rd motor mount. I will have to revert the 3rd mount idea to the rear.
Intercooler is setup for the future.
Top radiator support bracket will need to be made as well.
Almost done...Enjoy.
Old Jul 27, 2018 | 05:52 PM
  #32
Bnourai's Avatar
Bnourai
What an incredible work, send me your address I'm heading your way with mini we figure out the motor when I get there...lol I miss my S2000
Old Jul 28, 2018 | 05:12 AM
  #33
Apexlate's Avatar
Apexlate
Old Jul 28, 2018 | 08:07 AM
  #34
Whine not Walnuts's Avatar
Whine not Walnuts
I had two AP1s. If I was not an old fart with a bad hip would still have them but at 6-3 I was a sardine in it. MINI is allot easier to get in and out off and with my mods I have the S2000 HP beat and the torque, well the S2000 did not have too much so will not even go there but nothing can beat that 9000 rpm redline sound.
Back on topic, this is an amazing shade tree engineering effort.
Old Jul 29, 2018 | 08:11 AM
  #35
Kr4nG's Avatar
Kr4nG
Thank you all for the nice comment. I will be posting more until this thing starts up. Feel free to ask any questions.
Old Jul 31, 2018 | 11:51 AM
  #36
StingWay's Avatar
StingWay
Man, this is literally the dream!
What did you use for the ECU? does it work with the stock gauges?
Only thing that I dont understand right now.
Old Aug 1, 2018 | 08:29 AM
  #37
downshift1's Avatar
downshift1
He's using a K-Pro ecu
As for factory gauges that'll be interesting to see as they are all on a CAN bus. I've seen converters / Adapters but maybe an option to wire them directly?
Old Aug 11, 2018 | 08:29 AM
  #38
Kr4nG's Avatar
Kr4nG
Not much of an update. But good news is that the motor starts with the kpro. I have to find a good spot to go through the firewall so the new ECU can be inside the cabin. I have located all necessary wires except the fan control wire. I want to use the mini relay to start the new fan. If i cant find the wire then I will have to manually make my own relay circuit. Any suggestions where the fan control wire is on the Mini harness? Oh yea, the originally mini ecu does not need to connected at all. The key works and so does the power steering with the ignition on.
Working on the upper rad support bar.
Almost done..
Old Aug 21, 2018 | 01:57 PM
  #39
StingWay's Avatar
StingWay
Are you losing any features with this swap?
As in would all the alert lights work and gauges work?
super dope swap. Cant wait to see it finished!
Old Aug 21, 2018 | 06:00 PM
  #40
eyeckr's Avatar
eyeckr
Amazing!!
Old Aug 21, 2018 | 06:12 PM
  #41
Whine not Walnuts
Originally Posted by eyeckr
Amazing!!
Old Aug 21, 2018 | 09:05 PM
  #42
pjsjr13's Avatar
pjsjr13
Very impressive
Old Aug 22, 2018 | 04:50 AM
  #43
Kr4nG's Avatar
Kr4nG
I have lost A/C so far but that is easy to put back. I have also lost the RPM gauge. The speedo still works somehow. The stock mini ecu is out of the car so whatever that controls,its out. The new ecu gives me the new outputs so I can just wire in a new cluster.
Old Aug 22, 2018 | 08:37 AM
  #44
downshift1's Avatar
downshift1
Speedo should be coming off the can signal from the ABS module as it's wheel speed sensor driven (derived?).
For RPM you could try feeding the tack signal from the KPro to the tach directly?
Old Aug 23, 2018 | 05:58 PM
  #45
Kr4nG's Avatar
Kr4nG
the mini gauge cluster is all can bus. I dont have much knowledge about it.
Old Aug 31, 2018 | 10:21 AM
  #46
Kr4nG's Avatar
Kr4nG
I have a quick update for you all. The car runs!! I have finally finished the 3rd motor mount and the car is road ready. I need to figure out what to do with gauge cluster cause I can't see my RPM. In the mean time I will have my phone or ipad setup. The kpro has built in bluetooth so I can see all the parameters in live time. I will post more pictures at its current state next week.
Old Sep 5, 2018 | 11:26 PM
  #47
Stripeknight's Avatar
Stripeknight
amazing engineering. I really love this type of effort.
Old Sep 6, 2018 | 07:23 AM
  #48
IQRaceworks's Avatar
IQRaceworks
What are you doing to do about all of the electronics/PCM? Are you gutting the car and using all of the ACURA stuff? Isn't pretty much everything the car in one way or another handles by the MINI PCM? power windows, door locks, gauges, lights, a/c and vent controls, air bags, ABS brakes, engine management, etc, etc, etc........
I've always wanted to do an engine swap.......but not knowing what to do about all of the electronics really has turned off of the whole idea.
Also......keep an eye on those welds. I've used those cheap flux core mig welders before.....even if they look nice, they can be very weak and full of porosity....and will break on you. Just a word of warning......
Old Sep 10, 2018 | 05:20 PM
  #49
Kr4nG's Avatar
Kr4nG
thanks for the warning on the welds. I know its a cheap welder and I'm gonna keep a close eye out. As far as the electronics go. Everything is normal except the a/c button and rpm gauge. The Engine light, Oil pressure, and Battery light is not done yet. I will manually add the wires to a used cluster and put them in. Speedo works like normal and DTC button obviously doesnt work. The Kpro has a can bus output. I could be brave and just plug that into the cluster to see what may happen.
Old Sep 10, 2018 | 05:55 PM
  #50
IQRaceworks
What about the power windows, gauge lights, interior lights, headlight/tail lights, blinkers, radio, etc, etc,......does all of that stuff work?
