Mini/MINI BUILDS Showcase your Build Talents.
Lightly Modifying My F56
Old May 20, 2016 | 07:44 PM
  #76
vetsvette's Avatar
vetsvette
Moderator
Correct. Mine has the Sport suspension. I think the springs will work with the DDC if that's what you're wondering. Give Jerry a call at NM. He'll give you the straight scoop.
Old May 20, 2016 | 08:00 PM
  #77
Blues Trucker's Avatar
Blues Trucker
That is what I was wondering. Mine has the sport suspension and DDC.
Old May 20, 2016 | 08:19 PM
  #78
vetsvette's Avatar
vetsvette
Moderator
Incorrectamundo! If you don't have a standard suspension you have a DDC. In the '16 models only the JCW came with sport suspension. It was discontinued as an option for the S after the '15 model. The DDC has a sport setting, but it's not as aggressive as the sport suspension. The code for the sport suspension option was 226. I see you have the "Sport Package", but that only includes updated lights, wheels, etc. Nothing to do with the suspension.
I think you will be impressed with the handling if in fact you can use the springs. The sway bar, end links, and control arms are compatible for sure.
Let us know what you find out when you speak with Jerry. Personally, I'm betting the springs will work fine.
Old May 20, 2016 | 09:08 PM
  #79
Blues Trucker
Ahh. Got it.
Old May 21, 2016 | 09:54 PM
  #80
vetsvette's Avatar
vetsvette
Moderator
Oops! Duplicate post.
Old May 22, 2016 | 04:29 PM
  #81
toyopet's Avatar
toyopet
cravenspeed mounts
vetvette, how sturdy are the nav and scangauge mounts? Do they shake at all while driving over bumpy roads? Thanks.
Old May 22, 2016 | 07:52 PM
  #82
vetsvette's Avatar
vetsvette
Moderator
Very solid. I had them in my R56 too. Great stuff!
Old May 23, 2016 | 06:25 PM
  #83
MarcoPolo's Avatar
MarcoPolo
have you done any post-install datalogging with the IC...just got home from getting mine done...want to compare values...specifically what is the difference between your IAT and ambient temps.
Old May 23, 2016 | 06:34 PM
  #84
vetsvette's Avatar
vetsvette
Moderator
Haven't had a chance to do much of anything. Either I've been working on the car or the weather has sucked.
Old May 24, 2016 | 07:57 AM
  #85
[QUOTE=vetsvette;4209327]Well, today was a busy one. Added a couple more things.
These...
The blue one...
Couple of these grey ones...
Bad picture of the adjustable rear control arms.
This shows the new rear brakes, spring, swaybar, stainless lines, and end links.
Front brakes were installed with NM stainless brake lines. I was worried for a moment that the wheels wouldn't fit over these rotors. Things are huge!
Brakes with wheels installed...
Topped it all off with a strut brace by NM.
Only downside of this work is I lost all the coding I had done at the Dragon. Software has to be updated for the JCW brakes and once the program starts to run it updates everything. Small price to pay for these brakes though.
The springs closed the wheel well gap nicely too.
Before...
After...
Well done, Like the NM Eng set up.
Old May 24, 2016 | 09:50 AM
  #86
honderpilot's Avatar
honderpilot
Here ya go. This is with about 150 miles on them. Shiny!
Also added some go-fast decals. Suspension from NM. Intercooler from Helix. Everything but the I/C installed and tweaked by G3 Automotive.
There ya go looks great man! Keep up the good work.
Old Jun 16, 2016 | 04:13 PM
  #87
toyopet's Avatar
toyopet
They have F56 specific programming for the ScanGauge II. I kept mine from my R56 and sent it back to the manufacturer for the update. No charge for update or shipping back to me. I only paid to mail it to them. You can actually monitor oil pressure on it now. I use the Cravenspeed ScanGauge mount. Works great.
How did you mount the scangauge on the left side by the tach?
Old Jun 16, 2016 | 04:28 PM
  #88
vetsvette's Avatar
vetsvette
Moderator
Used a longer screw and mounted the arm to one of the Garmin mounting holes. I'll see if I can get a picture of the rear of the Tach/speedo tomorrow when it cools off a little. I'll have to extend the steering column and lower it to be able to see it.
Old Jun 16, 2016 | 06:20 PM
  #89
jlb's Avatar
jlb
Car looks great!
Old Jun 16, 2016 | 06:44 PM
  #90
vetsvette's Avatar
vetsvette
Moderator
Thanks. Still a work in progress.
Old Jun 16, 2016 | 10:01 PM
  #91
J_L's Avatar
J_L
How do the brakes feel around town or mountain roads? Firmer pedal, more in control? Or would need to really push it hard to notice a difference?
Old Jun 16, 2016 | 10:19 PM
  #92
vetsvette's Avatar
vetsvette
Moderator
Brakes feel great. I would recommend anyone doing this mod install braided stainless lines. That'll help get rid of the soft pedal feel some people experience when using the stock rubber lines. Pedal doesn't feel that much different from the standard S, but when you really get on them it feels like you're gonna do a nose wheelie. I'll be in the mountains of western NC next weekend and hope to have enough time to hit the Dragon for a couple of runs. I'll have a better feel for the brake and suspension mods then.
The brakes are definitely a mod I would recommend, but remember, you'll need to invest in different wheels and stainless lines too. Adds up pretty quick.
Old Jul 28, 2016 | 12:25 PM
  #93
vetsvette's Avatar
vetsvette
Moderator
Just finished installing my AC Schnitzer splitter. Pretty straight forward job as long as you make sure they send the correct hardware. This is on a MCS. You folks with a JCW may have a different experience. I'll have better pictures soon. Too frackin' hot right now.
Old Jul 28, 2016 | 02:13 PM
  #94
MoJo4Twenty's Avatar
MoJo4Twenty
Subtle yet effective! Bet you can't stop looking at it huh! For the price, it isn't too bad either.
Old Jul 28, 2016 | 03:59 PM
  #95
Mini Mania's Avatar
F56
Very nice, looks great!
Old Jul 28, 2016 | 05:34 PM
  #96
vetsvette's Avatar
vetsvette
Moderator
Thanks.
Old Jul 28, 2016 | 05:54 PM
  #97
trouble1943's Avatar
trouble1943
Originally Posted by J_L
Looking great. I thought that the JCW exhaust kit had to be installed at the dealer, so they could do the ECU flash. No? What's the reality? And how many hours labor did your tech charge?
Was quoted $2,,500 for tuner exhaust and ecu flash. Got it for $2,000. You have to have dealer install because it is the ecu flash that gets you the extra 30 horsepower.
Got mine before picking up new Cooper S last week and it totally rocks.
Old Jul 28, 2016 | 06:37 PM
  #98
vetsvette's Avatar
vetsvette
Moderator
My independent Mini/BMW tech has the BMW software on his computer and was able to update my software at the same time he installed the tune. All you need is the software and the code specific to that particular kit. I still have the paperwork with the code if there's ever a problem in the future.
Old Jul 28, 2016 | 06:40 PM
  #99
MarcoPolo's Avatar
MarcoPolo
and if i'm not mistaken, you need to submit your vin and they spit out a software that is specific to your car. you can't just flash the jcw tune to any vehicle w/out a vin.
am i right?
Old Jul 28, 2016 | 07:15 PM
  #100
vetsvette's Avatar
vetsvette
Moderator
If I'm not mistaken, the computer will read the VIN when It's hooked up to flash the ECU. The tune is not assigned a VIN until that time. My tech still has the tune from a kit he sold to another member with a JCW. He only charged for the exhaust system and installation so he still has a tune he can use on any 3rd Gen MCS the he wants.
