Gas Tank Capacity & Mileage
Old Apr 22, 2007 | 02:27 PM
Dave_07's Avatar
Dave_07
Has anyone else noticed that the tank capacity on an '07 non-S seems to be about 14.5 gallons instead of ten and change as advertised? I've only got a couple of fill ups on the car, but they seem to consistently point to over 14 gallon capacity. This is a good thing IMO.
Also I noticed that the calculated MPG is higher than actual by 2-3 MPG. We are getting between 32 and 35 MPG mixed driving but the calculated average after resetting reads 35-37. This is probably a software update.
Old Apr 23, 2007 | 11:25 AM
Rennie's Avatar
Rennie
There were two threads on the gas tank capacity subject in the R56 area that were merged into one. It seems everyone is getting more than the 10.6 gallon capacity the manual states. I posted there that my MA told me that for some reason MINI is very vague about this topic, and that the R56 gas tank capacity is actually 13.8. I'm not sure how he knows this, but based on reading all the posts at the other thread, the MC definitely does not have only a 10.6 gallon capacity.
Edited to add the link to that other thread: https://www.northamericanmotoring.co...light=capacity
Old Apr 25, 2007 | 07:50 AM
Klasse Act's Avatar
Klasse Act
On a somewhat related note my first mileage reading for the car was 29.2 and that's mixed driving w/o the sport button on. My next reading came out to 29.5 w/ the sport button on and exhaust system added. I'm looking forward to taking a trip to Grand Rapids next month where I'll be able to see what the freeway mileage is like, I expect better than the 36 mpg its rated at though.
Old Apr 25, 2007 | 07:54 AM
Loony2N's Avatar
Loony2N
Based on prior posts, it appears both the MC and MCS in the States are getting 13.2 gal tanks. This is "useable" tank capacity only and does include the filler neck and intended air space area in the tank.
Old Apr 25, 2007 | 08:04 AM
Ryephile's Avatar
Ryephile
The most I've filled up with was 13.0 gallons. The fuel pie was on the last red slice and the display on the tach had brought up the low-fuel warning 3 times, with the OBC showing 30 miles 'til empty.
FWIW, a friend of mine that has an '02 R53 has had his OBC go beyond 0 miles until empty; it actually just flat-lines, LOL. His fuel gauge is off because at that point he only fills up with about 12 & 3/4 gallons. I wouldn't bet the system on the R56 is the same however.
Old May 3, 2007 | 08:52 PM
Jimbo94501's Avatar
Jimbo94501
I had the drain the tank on my 07 non S. They believe it to be 13+ gals I still think it is more.
Old Jun 8, 2007 | 03:44 PM
eightysixdown's Avatar
eightysixdown
2nd fillup I did 13.288, with 25 miles left on the obc. I want to drive it empty with a gas can to see if the obc is straight up or if there's more reserve...
Old Jun 8, 2007 | 07:31 PM
Skuzzy's Avatar
Skuzzy
I just put in 12.38 U.S. gallons in Romi. The trip computer said I had 64 miles left to travel and was at 30.1MPG.
So, 64/30.1 = 2.126 U.S. gallons + 12.38 U.S. gallons to fill = 14.4 U.S.gallons.
There were two candy corns left in the fuel gauge, and Romi was complaining about being low on fuel.
Last tank calculated to be 14.5 U.S. gallons as well. This all assumes the trip computer is actually doing the calculations correctly.
Old Jun 8, 2007 | 09:01 PM
lava's Avatar
lava
I had 30.1 after my first fill up. Last time I looked it was over 32. I got to get my foot in it more...
Old Jun 12, 2007 | 08:02 AM
mrweasel's Avatar
mrweasel
last fill was 13.2 gal with 22 left on the OBC...avg 35.2mpg on the BC, avg speed 36.3mph, range 448mi
Old Jun 15, 2007 | 08:15 AM
chili s's Avatar
chili s
Beat you all. I had 16 miles left according to the 'puter when I filled up with 13.9 gallons. $48+ to fill up.
Old Jun 15, 2007 | 08:19 AM
mrweasel's Avatar
mrweasel
Originally Posted by chili s
$48+ to fill up.
That's the part that hurts
Damn you, premium petrol!
Old Jun 15, 2007 | 09:08 AM
TheBigNewt's Avatar
TheBigNewt
That would be about 13.8
That would be about 14.4 as others have estimated. 'Cmon, somebody run her dry and give us the real truth!
Old Jun 15, 2007 | 02:17 PM
rtjonesjr's Avatar
rtjonesjr
Just look at the MiniUsa.com web site. It says 13.2 gallons.
My range on a tank of gas is over 600 miles. http://www.miniusa.com/#/learn/FACTS...l_Efficiency-s
Old Jun 15, 2007 | 04:02 PM
Skuzzy's Avatar
Skuzzy
Ok, if the gas tank is 13.2 gallons, then the last two candy corns in the fuel gauge represent roughly 1 gallon of fuel. I happen to fill up almost immediately after getting the warning for low fuel and Romi took 12.1 gallons U.S. No topping off.
I am not saying that the last two candy corns cannot represent only 1 gallon of fuel, but why would they do that? It would be very odd.
Old Jun 15, 2007 | 04:26 PM
dwjj's Avatar
dwjj
13.2 is nominal capacity. It doesn't include an expansion area, the filler tube, a little bit of "extra" reserve.
There's a little bit of gas above and beyond that that's inaccessible-it would help at the end of the tank keep the fuel pump cooled(you don't want to totally run out too often-the pump motor won't take it). A couple of people have driven on "0" for a little ways and haven't actually ran totally out.
Old Jun 15, 2007 | 06:04 PM
eklebaur's Avatar
eklebaur
I have run a test on nine different fill-ups on my '06 MC; where I take the gallons I put in the tank and add to that the calculated gallons remaining, based on range and avg mpg. I average 14.3 gallons over those nine fill-ups as a total tank capacity. The highest capacity that I have calculated is 14.7 gals. (added 11.8 gals. with range of 102 miles/2.9 gals. remaining) and the lowest is 14.0 gals. (added 12.1 gal. with range of 69 miles/1.9 gallons remaining).
Old Jun 15, 2007 | 07:53 PM
dwjj's Avatar
dwjj
Until you run it out, you really don't know the capacity.
Old Jun 15, 2007 | 11:26 PM
TheBigNewt's Avatar
TheBigNewt
Exactly. When the OBC says zero there still could be a gallon or 2 left.
Old Jul 2, 2007 | 03:06 PM
ejkd's Avatar
ejkd
Don't do that again. I read in the owner's manual to fill up when it's 30 miles
left.
Old Jul 2, 2007 | 04:26 PM
mikeg4572's Avatar
mikeg4572
I filled up with 14.2 one day. I had about 9-10 miles left till empty, at least according to the computer.
Old Jul 11, 2007 | 09:22 PM
OasisT's Avatar
OasisT
On my way home from Atlanta after receiving a speeding ticket, I drove 300 miles at 70mph and got an astounding 42mpg! Wow, thats much better than the sticker of 36 hwy mpg. I then took a trip to Milwaukee with a stuffed Mini with 4 wheels/tires/jack/3 suit cases and a passenger and got 37 mpg.
R3411y
Nov 23, 2015 01:10 PM
12R58JCW
R58 :: Coupé Talk (2012+)
Sep 17, 2015 12:21 PM
kjd186
Sep 9, 2015 10:02 AM
eliseo1981
Sep 4, 2015 02:33 PM
