Offset recommendations for 07 MCS
Old Apr 17, 2007 | 07:45 PM
Iautox's Avatar
Iautox
Hi,
I'm looking for a set of Rota D2's for a 2007 Mini Cooper S. It appears I will have to order them to get silver ones. I'm going to get some 16 x 7s. The stock rims are 16 x 6.5 with an offset of 48 and tires are 195/55/16. I'll be looking to put 215/50/16's on which are the same diameter as the stock tires but have a shoulder width of 8.8 inches as compared to the stock width of 7.9.
I believe I can order any offset. If I find some that are already in inventory I think the two best offsets are 40 and 35.
Recommendations, especially from people who have fit some aftermarket wheels up on 07s, would be greatly appreciated.
Thanks,
Mark
Old Apr 20, 2007 | 11:13 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by Iautox
Hi,
Thanks,
Mark
Mark,
Here is a similar situation with R56 and 215/50-16 tires. 16x7 rim used with offset +38mm. Most likely +40mm offset is OK.
https://www.northamericanmotoring.co...ad.php?t=98563
For best fitment talk to Alex@tirerack.com or email him. A bigger offset number means the tire sits toward the inside of the wheel well and smaller number means the tire will stick out beyond the fenders. Rubbing occurs on the inside in the rear with the lower trailing arm and sometimes with square designed upgraded rear sway bars and rubs in the front against the larger R56 brake calipers.
Kimolaoha
Dec 5, 2020 09:32 PM
Steeroidz
Aug 29, 2018 07:41 AM
HaveATank
Sep 4, 2015 08:04 AM
TOMSR53
Aug 26, 2015 10:18 AM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
