Drivetrain SpiderX's Header from CMC (Juston Poole)
Old Apr 13, 2007 | 10:02 PM
SpiderX's Avatar
SpiderX
This is the header on my car...... SpiderX made about 215 with best tune before and 225 after..... so far... We hope we can wring it out to 235 WHP while maintaining great tq and driveability...... note there are real collectors and the primaries are stepped...... ceramic coated with a titanium finish......
Juston has experience building headers for Porsche, BMW as well as Honda and others......
This header was conceived assembled specifically for my 62 car ..... works quite well and I am VERY happy with it.
Old Apr 13, 2007 | 10:26 PM
goaljnky's Avatar
goaljnky
Pretty. Couple of questions.
1. What does stepped mean?
2. What is the purpose of #1 & #4 going into one collector (I hope I got that right) and #2 & #3 into the other vs. #1 & #2 and #3 & #4 mating up?
Old Apr 14, 2007 | 01:51 AM
a610's Avatar
a610
1. Stepped means that the pipes start with one diameter, then change to another diameter.
2. Merging the exhaust pipes in this fashion makes for better scavenging of the exhaust gasses, since the 2 cylinders joined are 180* apart in firing order.
Old Apr 14, 2007 | 04:56 AM
SpiderX's Avatar
SpiderX
I was out with GF last night and just saw this.... (I am trying to have a life) thanks for the post
Old Apr 14, 2007 | 05:05 AM
TLMCS05's Avatar
TLMCS05
New GF or recycle? How's her performance? LOL
Has Justin determined a $ range and availabilty yet or is it too early in the process? Looks like a well made header for sure.
Tim
Old Apr 14, 2007 | 05:10 AM
SpiderX's Avatar
SpiderX
Tim
She missed me.... what can I say..... (you know how I felt)
If you look at the M7-62 thread there are pictures of the unit he built for "hornguys" he charged Jim $950 I think....... Juston is taking orders and is ready to go..... please understand these are made by him one at a time in his shop in Sandy Springs GA (Atlanta) and I think he charges more if you watch and double if you help.
A 4X1 would be less
Old Apr 14, 2007 | 06:26 AM
hornguys's Avatar
hornguys
TLMCS05,
Mine included installation and the removable cat design, plus a custom heat shield.
And the ceramic coating.
You can see/hear it next Friday when we meet.
And see how it works with the Exedy stage 3 clutch/flywheel...
Old Apr 14, 2007 | 06:30 AM
TLMCS05's Avatar
TLMCS05
Cool! Not a bad price range for a custom header. I'm thinking of selling off some long unused toys and going ahead this summer and taking blu to the next level. Thanks for the info and product updates.
And Bob, share the secret to finding cute blind women? Glad things have worked out like they were supposed to!
Tim
Old Apr 14, 2007 | 07:37 AM
minimusprime's Avatar
minimusprime
I don't think I've ever been so happy to be living near GA in my life.... Thank you Jouston
Old Apr 14, 2007 | 08:14 AM
goaljnky's Avatar
goaljnky
Thanks.
Old Apr 14, 2007 | 08:40 AM
minimc's Avatar
minimc
The reason for the steps in the primaries is to maintain velocity within the first few thousand rpm. The step up can have several functions, depending on design, but the most basic is: The increase in diameter allows greater flow at rpm just beyond those (rpm) which the shorter section was tuned for. The overall goal being to eek every ounce of torque out of the engine within various operating ranges. The steps do this effetively and make the car more drivable/fun to drive. As described earlier, the significance of pairing cylinders which are 180 degrees appart in firing sequence is to 'scavenge'. As a pulse of gas (from cyl 1) passes the "Y" in the pairing a negative pressure wave travels up the other leg (cyl 4 in this case). The lengths of the primaries are designed so that at the moment the negative wave is hitting the exhaust port the intake valve is open, and cylinder is filling. The effect: The intake charge, in addition to being pushed into the cyl (by the S/C) is also 'sucked' in by the negative pressure wave... a very short duration low-pressure zone, which allows maximal cylinder filling, and in doing so limits the amount of exhaust gases which might reverse-flow back into the cyl. (when the intake valve closes).
Old Apr 14, 2007 | 08:42 AM
SpiderX's Avatar
SpiderX
Originally Posted by minimc
The reason for the steps in the primaries is to maintain velocity within the first few thousand rpm. The step up can have several functions, depending on design, but the most basic is: The increase in diameter allows greater flow at rpm just beyond those (rpm) which the shorter section was tuned for. The overall goal being to eek every once of torque out of the engine within various operating ranges. The steps do this effetively and make the care more drivable/fun to drive. As described earlier, the significance of pairing cylinders which are 180 degrees appart in firing sequence is to 'scavenge'. As a pulse of gas (from cyl 1) passes the "Y" in the pairing a negative pressure wave travels up the leg of cyl 4. The length is designed so that at the moment the negative wave is hitting the exhaust port the intake valve is open. The effect: intake charge, in addition to being pushed into the cyl (by the S/C) is also 'sucked' in by the negative pressure wave... a very short duration low-pressure zone which allows maximal filling, and in doing so limits the amount of exhaust gases which might reverse-flow back into the cyl. when the intake valve closes.
thanks....nicely done
Old Apr 14, 2007 | 08:53 AM
goaljnky's Avatar
goaljnky
^x2. Simple and to the point. Thanks for the education.
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:13 PM
PhoR53
Sep 30, 2015 06:54 AM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:11 PM
