R56 Roofs insulated???
Old Apr 11, 2007 | 10:21 AM
S2ki.com's Avatar
S2ki.com
Roofs insulated???
Are the roofs insulated at all? I was driving my girl's Cooper yesterday and it was raining cats and dogs. It sounds like a freaking tin can, super loud, enough that you have to raise your voice just a bit. It's a hollow tin can sound.
Old Apr 11, 2007 | 12:55 PM
msh441's Avatar
msh441
Hmmm... hard for me to tell. I have a sunroof.
I will say the headliner feels a bit thin. Well, maybe not thin, but lightweigt. I would guess there's not much up there, myself.
Old Apr 11, 2007 | 01:00 PM
Loony2N's Avatar
Loony2N
The roof IS the insulation.
Old Apr 11, 2007 | 09:31 PM
surfblue's Avatar
surfblue
[quote=S2ki.com;1470795]Are the roofs insulated at all? I was driving my girl's Cooper yesterday and it was raining cats and dogs. It sounds like a freaking tin can, super loud, enough that you have to raise your voice just a bit. It's a hollow tin can sound.[/quote
Turn the stereo up! Or go to Lowe's and buy some insulation and roll it up there. That'll look real different.
Old Apr 20, 2007 | 06:40 AM
S2ki.com's Avatar
S2ki.com
I also have the sunroof...
Old Apr 20, 2007 | 07:13 AM
Skuzzy's Avatar
Skuzzy
I will be pulling my headliner out when mine arrives, so I will be able to let you know then.
Old Apr 20, 2007 | 07:14 AM
Loony2N's Avatar
Loony2N
To match what you've done to your head waiting for your MINI?
Old Apr 20, 2007 | 06:37 PM
ygblat's Avatar
ygblat
Old Apr 20, 2007 | 06:56 PM
mikeg4572's Avatar
mikeg4572
I was in there when I was hard wiring my V1 there is not any insulation other than something that looks like cardboard. There was a lot of room in there.
Old Apr 20, 2007 | 07:59 PM
daffodildeb's Avatar
daffodildeb
Why are you pulling out your headliner, Skuzzy?
No wonder it's taking so long--the poor thing is scared to come over!
Old Apr 20, 2007 | 09:00 PM
BritBoy's Avatar
BritBoy
The shop foreman at East bay Mini told me yesterday that the tintops have a single piece of cardboard above the headliner and those with sunroofs have bugger all.
Old Apr 21, 2007 | 03:24 AM
Skuzzy's Avatar
Skuzzy
LOL LynnEl!
My primary reasons for pulling out the headliner is to look into adding some fiber optics to create Romi's (Andromeda) constellation. I want to have it just show up when it is dark, and be completely invisible when it is daylight.
I also want to see about adding other lighting for map lights and so on. Additional speakers for the HiFi system is something else.
Then I may want to add a drop down LCD panel I would use a couple of things.
And while I am there, I would take a look at the insulation. The roof is a large sheet of metal. Anytime you have a sheet metal panel that large, you have potential for all type of harmonis filtering into the cabin. A thin layer of urethane foam sprayed on will cure that and add mayne 6 to 8 ounces to the weight of the car.
Old Apr 21, 2007 | 04:48 AM
4xAAA's Avatar
4xAAA
I would be interested in how that goes Skuzzy. Maybe you could take some pics and give us a little DIY post.
I remember seeing some product used on Jeep Cherokees, it was a thin foam mat held down with glue. Thaey put it under the carpet in the storage area in the back. Might work even better than spray, less chance for overspray.
Old Apr 21, 2007 | 05:01 AM
Skuzzy's Avatar
Skuzzy
Oh, I plan on documenting it for all. The problem with any solid substance is the chance of it coming loose. The spray on urethane foam product I use will even adhere to an oil covered surface. Yes, one does have to be careful when applying it.
That is why I will simply gut the interior before I start the project. I suspect there are more areas I can add the damping material to.
When it dries, it is very stiff. I have used it before and it does an excellent job of killing high pitch sounds. It also seals the metal really well, preventing any type of direct moisture contact.
Old Apr 21, 2007 | 05:58 AM
Skuzzy's Avatar
Skuzzy
Oh now, come on. You of all people should understand she will want to look her best by the next MOTD, so she can strut her stuff. Dunt(tm) tell me you would not look forward to a day at the spa?
There are a lot of good things that come from better insulation. Properly done, it also helps improve the audio in the car.
USNAE2
16
Jun 17, 2022 07:17 AM
ian260
Mar 29, 2017 06:08 AM
bahman
Feb 14, 2016 10:29 AM
aldito2
Sep 30, 2015 10:44 AM
Giants9595
Sep 29, 2015 10:49 PM
