R50/53 Break Dust Noise
Old Apr 5, 2007 | 01:32 PM
GQ3205's Avatar
GQ3205
Break Dust Noise
I get a lot of noise when I press the breaks softly...the dealer says it is break dust. Any thoughts? If it is...anyway to clean it or reduce the noise?
Thanks.
Old Apr 5, 2007 | 04:14 PM
tools's Avatar
tools
are these new brake pads?
Old Apr 5, 2007 | 04:21 PM
buzzsaw's Avatar
buzzsaw
Thanks.
I also with 4700 miles.
Old Apr 5, 2007 | 06:14 PM
resmini's Avatar
resmini
Thanks.
Pull the wheels and clean the brake dust off everything you see.
Sounds kinda like a dealer excuse to do nothing.
Old Apr 6, 2007 | 09:11 AM
Mrs. Skurvy's Avatar
Mrs. Skurvy
I have that problem too, there are a few other threads re: this issue as well. I'm convinced it's due to cold weather. I noticed mine disappeared when it got warmer, but now that we have another cold spell, the sqeal is back.
Old Apr 6, 2007 | 09:29 AM
Mrs. Skurvy
https://www.northamericanmotoring.co...99#post1458699
Old Apr 6, 2007 | 05:34 PM
Capt_bj's Avatar
Capt_bj
nosqueek
02 S
65,000 miles
replaced brAKEe pads at 55k
no squeek on original - very dusty pads
or on the nearly dust free EBC Greens.....
Old Apr 6, 2007 | 08:15 PM
iceckid's Avatar
iceckid
Im at around 5500 miles and my brakes sqeak on occasion. I dont mind and its not often. Ive been brought up thinking that when theyre working, brakes will squeak. With racing pads im sure would be alot louder, but im not there yet.
Old Apr 7, 2007 | 07:40 AM
ksmaas1's Avatar
ksmaas1
This problem has been around for decades. The squeek is actually a high frequency virbation bewteen the Back of the pad (where it touches the caliper piston, not where it touches the rotor). It's more common on wider pads and on pads with semi metalic content. The way to stop it is to remove the pad and and spray the steel BACK of the bad with Permatex Brake Quiet (there are other brands too). It's a sticky stuff that absorbs the vibration by essentially adhearing the bad to the piston. You can also buy shims that are peel and stick that will help. Moss sells them under the Mossmotors.com web site (not mossmini.com) because it's very common in Triumphs.
I've even had occasional success by spraying the back of the pads with paint and quickly aseembling before it can dry.
Brake dust has nothing to do with it.
lweaver
Sep 17, 2024 08:22 AM
BernieCoop
Sep 10, 2021 03:15 AM
Supertractor3
Apr 7, 2017 11:16 AM
Tires, Wheels & Brakes
Sep 10, 2015 03:10 PM
Sep 4, 2015 09:23 AM
