R56 Aux input - can Sat radio go right in?
Old Mar 22, 2007 | 08:23 AM
moots's Avatar
moots
Since the factory install is not available for a while - any one know when we can bring back our 07's for this?
Does the aux in allow easier install of sat radio without FM transmitter?
Old Mar 22, 2007 | 09:36 AM
Optimum CableGuy's Avatar
Optimum CableGuy
Yep.............
Old Mar 22, 2007 | 10:03 AM
Loui's Avatar
Loui
My MA tells me it will be early summer or late spring before a module will be available. It will be Sirrus. Nothing until then. No idea about the aux.
Old Mar 22, 2007 | 02:42 PM
minimaximini's Avatar
minimaximini
Pioneer Inno on Aux In
Works very very nice. Portable device. I strap it on the tachometer (a blasphemy!) with the Belkin Sports Arm Band. It receives great signal on that spot, doesn't slide off and it is easy to route the audio out cable to the Aux input. Also easy to change channels - right in front of you.
Now - if I only can find a mixer (heh!) for the aux input - to use it with the nuvi and Inno in the same input - that would be just perfect.
MMM
Old Mar 22, 2007 | 02:50 PM
msh441's Avatar
msh441
That's for the MINI unit...
...current Sirrus modules will plug right in (as well as iPods and other mp3 players).
Old Mar 22, 2007 | 02:57 PM
Phil K's Avatar
Phil K
MMM
So in other words the Aux input is all that's needed, the cigarette lighter outlet isn't required for power? Also, I'd be real curious to see what your Belkin Sports Arm Band set-up looks like. Any chance you'd be willing to post a picture? Thanks.
Old Mar 22, 2007 | 03:11 PM
Golsco's Avatar
Golsco
You will need the lighter outlet for power. You can also hardwire power into the fusebox which is often a simple task.
You will also have to run the satellite antenna, simple as well. A car stereo store should do it for 40 bucks if you buy the equipment there, maybe a little higher if not.
Old Mar 22, 2007 | 05:55 PM
Phil K's Avatar
Phil K
Thanks for that info. I've got an unprofessionally installed XM Roady unit in my current car, I won't do it that way again. The Mini's version of a Sirius lifetime membership is tied permanently to the car, I'm not crazy about that. Also, my MA told me that to install Sirius in the Mini without the lifetime membership would only save me a hundred dollars or so. That seems semi-absurd.
Old Mar 22, 2007 | 06:02 PM
Golsco's Avatar
Golsco
I've installed quite a few and the cubby, to me, is built for my sportster 4.
Filmy
15
Jun 6, 2023 06:27 AM
ducanero
Navigation/Audio
Oct 12, 2015 01:13 AM
Olenska
Sep 21, 2015 12:36 PM
Norton70
Sep 11, 2015 12:16 PM
Norton70
Sep 7, 2015 05:06 PM
