R50/53 is there anybody out there?
Old May 8, 2003 | 01:10 PM
koolmini's Avatar
koolmini
i don't know if this has been discussed before
does anybody else get really bad radio reception in there MINI's?
mine is really horrible.....
....what if my home plant tries to contact me
_________________
Old May 8, 2003 | 01:11 PM
VerucaSalt's Avatar
VerucaSalt
Coordinator :: Mid-Atlantic
Do you have a stock antenna or did you replace it?
Old May 8, 2003 | 01:12 PM
BankyEdwards's Avatar
BankyEdwards
mine's fine.... maybe the reception is bad because your home planet is trying to contact you
Old May 8, 2003 | 01:14 PM
jsun's Avatar
jsun
About what? "Get your butt back here and water me!"?
Old May 8, 2003 | 01:15 PM
dbwilldo's Avatar
dbwilldo
Coordinator :: Southern California MINI Maniacs
I have found the stock CD player in Roxy to have to best reception out of any car radio that I have ever had. Although my home planet has yet to try to contact me, I would almost bet that if the planets were correctly aligned they'd get through
8ball's Avatar
8ball
.. do your house plants try to contact you often?
..actually, mine is pretty good - even in hilly Seattle where reception is usually eratic, the MINI's radio pulls in signals nicely ...
Old May 8, 2003 | 01:19 PM
JoeS475's Avatar
JoeS475
My radio is OK, except it was awfull at Deals Gap. Too many mountains. I guess that is why many "locals" have those massive antennae on their trucks!
Oh, if the home planet does contact you, tell them I said Hi!
~Joe
Trippy's Avatar
Trippy
My reception is good with the stock antenna and the base-model radio/CD
Old May 8, 2003 | 01:23 PM
koolmini's Avatar
koolmini
it's stock
except for the "winter jack head"..........so they can spot me from the air, when they visit
Old May 8, 2003 | 01:28 PM
koolmini's Avatar
koolmini
that's just how we spell planet where i'm from
btw: i hate you guys
Old May 8, 2003 | 01:42 PM
fms's Avatar
fms
I only listen to FM, and the stations in my area must have strong signals. I can have my antenna off and I still pick up most stations well. I've got the Alta stubby, and I really like the look- much better than the long stock antenna.
Old May 8, 2003 | 01:44 PM
5280Motoring's Avatar
5280Motoring
Radio....radio....Is that the thing I hear when I'm changing CDs?
Actually, mine is pretty good. Not quite as strong as my last car, but I can still pick up 98.1 out of Colorado Springs, which is a good 80 miles south of where I am.
Old May 8, 2003 | 01:47 PM
chollomo's Avatar
chollomo
I think. tho you'll have to check you radio manual.. that there is a settign for local only stations, my last radio had this,, if you have this feature turned on it will only pick up the absolutly strongest signals. and may f*up others, I would check your manual and see if you're on that setting... also make sure you don't have the nav settign in teh radio on the proper setting for your car. Good luck.
Old May 8, 2003 | 01:57 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
If I ignore calls from my home plants they retaliate this time of year and have dandelion parties in my yard.
Old Jun 2, 2003 | 04:40 AM
koolmini's Avatar
koolmini
got the loose connection fixed :smile:
and have been contacted by my home planet and plant
