does anyone know how to reset the 'maintenace counter'?
I do all the work on my wife's mini and need to reset the 'maintenace counter'. does anyone know how to?
i've been searching for the past 20 minutes without any luck.
thanks
thanks
From MINI2...
How to reset the service interval indicator
DISCLAIMER:
The information below is based on the account of a MINI2 member. Although MINI2 and the author of this thread believe this information is accurate, using it as a DIY guide is done at your own risk. MINI2 and the author are not responsible for any damage, personal injury, or warranty issues that may arise from the use of this information. Some information below may be specific to model specifications that are unique to certain countries, and may not apply to your model of MINI One, Cooper, or Cooper S.
Do not undertake any DIY project that you are not qualified to perform. If you have questions about this project, you should consult with experienced professionals and/or your MINI dealer before undertaking it. Always follow standard safety guidelines for car repair in performing DIY projects.
The only time the following procedure should be performed on a vehicle still under Full Maintenance coverage would be when an owner chose to change their own oil on a SCHEDULED oil service. Doing it at any other time during this coverage will PUSH OUT the next service!
To reset the service interval indicator:
push trip button
turn ignition key to position 1 and 15A will appear to left of mileage
release trip button
wait 3 seconds
push trip button
wait (5 - 8 seconds) for RST to appear in left corner
release trip button
push trip button
15000 [or kilometer equivalent] will appear as new service interval
release trip button
The miles [or kilometers] until next service will now count down from the reset interval.
DISCLAIMER:
I get mine changed at the dealer for a few reasons.
1, it's not an easy filter to change, and with the O ring it can be done wrong and by the time you find out Jiffy Lube did it wrong, your motor is toast. If someone is going to mess up the oil change I want it to be the dealer, so I can make them replace my motor.
2, I have also been told a lot of places don't stoke the oil filter, could take a day for some places to get it, or they wont change the filter but say they did, etc.
I look at the dealer $60 oil change like an ins policy, plus at Jacobs there is free wifi, so I can work in the lobby for the 90 mins I'm there.
I won't void any warranty. Use of the wrong product, or doing it wrong, however, will.
simo711
Sep 29, 2015 11:53 AM
I feel so dirty reading this post.
