How to remove tree sap?
Old Feb 20, 2007 | 10:58 AM
Wagnbat's Avatar
Wagnbat
We just had an ice storm, and I park partially under a tree in front of my house. Over the past couple days since, I've gotten small clear dots on my windshield, only on the drivers side which sits under the tree, and I assume it's tree sap. I've scratched it with my fingernail and it won't come off... It's soft but not gooey.
What's the best way to get this off the windshield and paint?
Old Feb 20, 2007 | 11:01 AM
dazite's Avatar
dazite
Hot, soapy water...and a soft wash mit will do the trick. Or at least that is what we have to do.
Old Feb 20, 2007 | 01:19 PM
mcdbrendan's Avatar
mcdbrendan
Try Clay if that won't work.
Old Feb 20, 2007 | 01:43 PM
lotsie's Avatar
lotsie
The warm soapy water should work. I would lay the cloth on the spots for a few minutes to loosen/soften then, then try wiping. WD-40 will work also.
Mark
Old Feb 20, 2007 | 03:44 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
Bug and Tar remover (commonly availible at most autopart stores)
Old Feb 21, 2007 | 12:17 PM
Wagnbat's Avatar
Wagnbat
Interestingly enough, after last night's rain, almost all of the goo is gone. (no pun indended)
Old Feb 21, 2007 | 12:30 PM
RCE1's Avatar
RCE1
For Pine Sap...
Having tried a number of different options (a hundred year old Monterey Pine overhangs my driveway), I have found that plain rubbing alcohol works best for me. I use a soft cloth and plenty of 99% Isopropyl Alcohol and it takes even the stubbornest, crustiest pine sap off very easily. Last time I bought it, it was on sale at Safeway for $.99/pint. If the sap's on the windshield, I generally scrape it off with a razor blade, then use alcohol on anything that's left. Goo Gone also works well, as does WD-40. My detailer suggested Isopropyl Alcohol and that's what I've stuck with ever since.
Old Feb 21, 2007 | 12:32 PM
Minut's Avatar
Minut
Baby oil works too.
Old Feb 21, 2007 | 12:50 PM
Android993's Avatar
Android993
If all else fails use a bunson burner, sure to get it off.
The_Kid
Nov 3, 2016 06:30 PM
BRracing
Oct 24, 2015 10:07 PM
Sep 2, 2015 09:05 AM
broncobuddha
Sep 1, 2015 06:32 PM
Sep 1, 2015 04:02 PM
