cold weather shifting
Old Feb 12, 2007 | 05:59 PM
joecooper's Avatar
joecooper
in sub 25 degree weather the car doesnt want to shift entil it is completely warm up is this an issue anyone else has had and should i have this checked out
Old Feb 12, 2007 | 06:42 PM
lhoboy's Avatar
lhoboy
You have an atomic or manual tranny?
Old Feb 12, 2007 | 06:43 PM
lhoboy's Avatar
lhoboy
Either way, get it checked out. Even when starting up at 10 degrees, the shifting on my 6 speed doesn't seem to be any stiffer than normal. I had a Honda, though, that wouldn't change gears for the first 15 minutes when it got below minus 20 in Minnesota. I have no clue what's normal with an automatic.
Old Feb 12, 2007 | 08:58 PM
kapps's Avatar
kapps
I'm assuming you have a manual tranny. There has been some discussion about poor cold-weather shifting in the past. A trip to the dealer and some lubrication of the shift cables seems to solve the problem. All else being equal, it should be a little harder to shift in cold weather as the tranny fluid isn't in it's operating temp. Older cars tend to exhibit these symptoms more often as their syncro's are more worn down.
Old Feb 14, 2007 | 12:01 PM
joecooper's Avatar
joecooper
thanks for your help fellows ill have to make a trip to the dealer
Old Feb 14, 2007 | 02:20 PM
Wagnbat's Avatar
Wagnbat
I noticed at a red-light within the first 5 minutes of motoring this morning, it took a little more than usual to get into first... But aside from that, no issues.
potterstein
Dec 30, 2024 05:18 PM
dandw2
Sep 7, 2015 11:14 AM
dandw2
Sep 6, 2015 03:14 PM
tylewis
Sep 6, 2015 01:07 PM
SneedSpeed
Sep 2, 2015 05:34 AM
