Interior/Exterior Who has Head Light Protection?
Old May 3, 2003 | 11:30 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
Who makes the best head light protection kit? and does it cover all the lights? head lights, fogs, turn, and also the drving lights? how do they afix to the lights? glues or cling? do you like them? any help you guys can give me would be great. i see lots of kits out there, but they all kind of say the same thing. thanks
_________________
Electric Blue MINI S, Black Roof, Aero Kit, Rally Lights, Fog Lights, Xenon Head Lights, DSC, Harmon Kardon, Six-Speed, Sport & Cold Weather Packages, Cruise, 17" Wheels. Painted wheel lips. more mods to come. Plate: AGOKART
Old May 3, 2003 | 08:57 PM
mini-rolls's Avatar
mini-rolls
I have the x-pel kit but it is sitting in my home office, have yet to install.....
Old May 3, 2003 | 11:14 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I bought and installed the light protection kit from RandyBMC for $60
http://www.mini-motorsport.com/exterior.php
It is just a set (6 pieces) of clear 3M plastic which is cut to the about the right size and shape as the front headlights (need to specify whether for the xenons or standard lights because the shape is different due to the light washers) the turn/driving lights and the fog lights. Each plastic comes with a peel off backing. You clean the glass of each light with denatured alcohol to remove oils (cannot use rubbing alcohol), peel off the backing, place the protection sheet at one edge of the light and peel off more and more of the backing as you apply pressure to make the plastic stick to the light surface. It looks like a thick plastic sticker on your light. Smooth out the bubbles with your fingers from the center outward or from one side to the other. Takes a few minutes to install everything. There are six lights to do on my MCS and after the first two- the fog lamps, I was good in doing the rest- I saved the headlights for last and did a good job.
Since it is clear you can't really tell that they are there- no yellowing or cloudiness. no bubbles and it sticks good and the light of the headlights are great. They will protect my precious Xenons! Those lights are great. :evil:
Old May 25, 2003 | 11:12 AM
wjklos's Avatar
wjklos
I too have the X-Pel kit from Auto Clear Guard, installed it yesterday (bought it AFTER one of foglights got busted). comes with 8 pieces including the Rallly Lights. It's surprisingly thick stuff, and easier to work with if it's warm. I kept my pieces inside the car in the sun and used them as I needed them.
The parking lights are the easiest, the foglights are a little more difficult simply because they're recessed so far. The rally lights are curved so they're a little more challenging but are good practice for the headlamps (Xenon in my case).
The only issues I had with the headlights are the two small bubbles I have on each one after the process. I couldn't squeegee them out, so now I'm debating on pricking them with a pin.
Looks like they will be very clear once the water/alcohol solution evaporates completely underneath and the appear to be very sturdy/thick so maybe they'll work well.
I'm getting my broken fog replaced this week so I'll know how much I would've saved had I had them on to begin with.
Cheers,
Bill
Old May 25, 2003 | 01:35 PM
Lamin-x's Avatar
Lamin-x
http://www.lamin-x.com has light protection for the MC with or without washers. It's much easier to work with than the 40 or 80 mil StonGard or X-pel. Have kits for either just headlights or full front lighting. Clear, Optical Blue, Smoked, or Yellow too
Old May 27, 2003 | 02:45 AM
minihune's Avatar
minihune
I have had the lense protectors on for several weeks now and they are doing great. I had no real bubbles on installation. The directions say start at one end and work you way across to the other slowly and that is what I did with good success. The finished product is absolutely clear and you cannot easily tell that there is a clear protectant coat. No cracks or trouble with the clear film so far. Very nice.
Old May 27, 2003 | 08:02 PM
FraserBonnett's Avatar
FraserBonnett
Got headlights and turn signal protection kit from Mini Madness. Easy install, and you can only see where I buggered it up if you look really close.
Old May 27, 2003 | 10:29 PM
diamini's Avatar
diamini
http://www.diamondracinggroup.com/he...t_products.htm
$60.00
21303 Mini Cooper 2002- Head Lights, Fog Lights, Trun signals
21304 Mini Cooper-Washing Head Lights 2002- Head Lights, Fog Lights, Trun signals
We have been carring this product for a while.
All front lights covered.
phrza81
Oct 10, 2015 11:37 PM
cm.d
Aug 19, 2015 08:51 AM
jrezzo
Aug 9, 2015 10:32 PM
MIminiclubman
Aug 5, 2015 09:14 PM
