brake question
Old Jan 31, 2007 | 08:38 PM
mondsiu's Avatar
mondsiu
brake question
my mini cooper is producing a high pitch sound when breaking, brought to the dealer for break inspection and they say its fine, and the sound is normal -.- so any idea why is this happening? will changing the break pads help? any advice?
Old Feb 1, 2007 | 03:59 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Do you have alot of brake dust? If you do, thats the problem, if not...don't know what to tell you?
Old Feb 1, 2007 | 08:34 AM
MOE4me's Avatar
MOE4me
Most cars will produce a high pitched squeal just prior to breaking...this is accompanied by crunching sounds and often breaking glass.
If you are producing these sounds while braking, well that is just not good.
Sorry, couldn't help myself
Old Feb 1, 2007 | 08:49 AM
Louispup's Avatar
Louispup
My brakes "squeal" a little bit, (short sound, not prolonged). Had some fresh tires put on last week, (at a reputable shop) and they told me the brakes look good. Irksome. (I'll hit 20k while at lunch today).
Old Feb 1, 2007 | 09:46 PM
Grassroots Garage's Avatar
Grassroots Garage
OK, try this...
Find a nice empty parking lot (wher cops are not watching) and drive in reverse as fast as is safe, and hit the brakes MODERATLY, not enough to lock them up, but use firm pressure. Do this a few times and see what happens. The idea is to sort of back flush the dust that has accumulated in all the little pores in the pads. It has worked well for me in the past, and I've had lots of satisfied customers. Please make sure you do this in a safe environment and know what is around you (islands, parking stops, etc.)
--Dan
Old Feb 2, 2007 | 08:08 PM
mondsiu's Avatar
mondsiu
i will try this backward thing tomorrow thx dan
Old Feb 3, 2007 | 01:18 PM
chadtoolio's Avatar
chadtoolio
Ditto on the backing up and breaking method. We call it deglazing!
Old Feb 5, 2007 | 06:48 PM
lvbltec's Avatar
lvbltec
all brakes make noise u can try to get some bg pad friction modifier that should help with the noise but it is always there u just can't hear it at times
W0TM8
Dec 19, 2019 07:50 AM
thebordella
Aug 31, 2015 01:37 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
nomar116
Aug 10, 2015 11:24 PM
