Cheapest place to purchase power steering pump?
Old Jan 30, 2007 | 07:33 AM
Schwinn's Avatar
Schwinn
My power steering pump will not turn off unless I disconnect the battery. Looks like it is time to be replaced. It slowly started to mess up. For the last week or two it would turn on by itself after the car was off. I would go to the garage and it would be whinning. Well it ended up killing my battery once and now it is going non-stop.
I thought I saw somewhere online there were remanufactured pumps for less then $200 but can't find them. Any ideas where I can get one at a decent price?
Old Jan 30, 2007 | 09:15 AM
RaiderZA's Avatar
RaiderZA
Get it taken care of soon, before you become another statistic.
Check out the thread on spontaneous engine bay fires.
Old Jan 30, 2007 | 02:33 PM
SRICHS's Avatar
SRICHS
Hey. Give the guys at Patrick MINI a call, the guys name is john that works the parts counter for the MINI's. I was in a bind recently and he was able to save the day.
Old Jan 30, 2007 | 05:49 PM
Rawhyde's Avatar
Rawhyde
You need to get this fixed ASAP! Mine did it, but I was still under warranty. If you can't get it fixed immediately, at least go under the car and unplug it before you risk a fire.
Rawhyde
Old Jan 30, 2007 | 09:04 PM
Schwinn's Avatar
Schwinn
Yea...I disconnected the battery so hopefully should be good.
Old Feb 1, 2007 | 11:26 AM
Mab01uk's Avatar
Mab01uk
BBA Reman a company based in both UK (& MA in USA) well known in the motor trade for specialising in supply of ECUs, ABS units, etc, can now supply rebuilt / reconditioned MINI power steering pumps with a 2 year warranty at a lower cost than BMW. ( Approx. 140 UK pounds + postage.)
BBA-reman.com
Old Feb 1, 2007 | 02:13 PM
Scooby03's Avatar
Scooby03
If you can't get one for some reason, I have one instock.
Brad
Custom Mini Shop
Old Feb 1, 2007 | 05:09 PM
Warped1966's Avatar
Warped1966
I'm a newbie so please forgive my ignorance but... Wouldn't the sensor/switch that triggers the pump be the suspect rather than the pump itself? Or is the sensor/switch integrated into the pump?
Old Feb 1, 2007 | 05:25 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
I would check your relay under the hood.
Old Feb 1, 2007 | 05:32 PM
th3118's Avatar
th3118
I justed looked and couldn't find a relay for the steering. I've lent my manual to a friend so I'm no help. It would suck to buy a pump and find out it was something else.
Old Feb 2, 2007 | 06:00 AM
Schwinn's Avatar
Schwinn
Makes sense...I did a little bit of reading and found someone that had the same symptoms where their pump would not turn off. In their case it was a faulty pump. If there was a relay or switch that would make sense though.
Old Apr 15, 2007 | 03:39 PM
CooperSPR's Avatar
CooperSPR
From what I have been able to dig up, it seems to always be a faulty pump. I have to replace my pump now too, just out of warranty. I have been able to find a pump, but not "how to" instructions. Any one know how to replace the pump?
Etrain
16
Aug 5, 2024 04:37 AM
theblackfalcon
Oct 11, 2015 09:49 AM
JPMontes3
Aug 23, 2015 01:26 AM
azntaiji
Aug 13, 2015 03:24 PM
minipopkart
Aug 13, 2015 05:22 AM
