Rear brake wear...
Old Jan 29, 2007 | 11:23 AM
meb's Avatar
meb
Rear brake wear...
how many miles are you folks getting from your rear brakes? I've been averaging 27K miles - 3 sets so far. I'm told this is normal for this car...every other front driver I've owned has gone over 100K miles.
Old Jan 29, 2007 | 11:28 AM
txwerks's Avatar
txwerks
First set of OEM pads lasted about 30K miles, even with lots of track days and 2 full seasons of autocross... I replaced the fronts three times. Front rotors were replaced once before I went BBK...
Cobalt GT-S pads that are on now (rear) have made it another 12K miles and barely show any wear - even with lots of track days and a full season of AX.
I'm pretty easy on brakes, tho... I know plenty of other people that haven't had anywhere near the same experience as me...
Old Jan 30, 2007 | 11:30 AM
bean's Avatar
bean
i replaced my stock rear pads at 7k....sebring and homestead haven't been kind to my brake pads. this was while installing the third set of BP-20 pads in my TCE 13" front setup...
txwerks: aren't you running the porterfield R4?
Old Jan 30, 2007 | 11:48 AM
txwerks's Avatar
txwerks
One car has Cobalt GT-S pads in the rear and the Brake Man BBK up front (with #3 pads)... As soon as the GT-S pads bite the dirt, we'll swap on R4's in the rear.
The other car (primarily track only) has a Wilwood 11.75 kit (B's for track, E's for driving to the track) and R4's in the rear...
Old Jan 30, 2007 | 11:56 AM
mbcoops's Avatar
mbcoops
So why is it that the rears wear before the fronts? This doesn't make logical sense to me - my rears were replaced at around 35k, and my fronts at 50k.
mb
bean's Avatar
bean
txwerks: i'm switching to b's in the front for my next track outing. will the R4 pads in the rear give me a good brake bias. i switched to 225/40/17 hoosier R6's for the last event. before this switch, on Ra-1's, the car was very unsettled under hard braking. i'm looking to keep the balance of the BP-20 front/oem rear in a package w/ more torque.
Old Jan 30, 2007 | 12:21 PM
txwerks's Avatar
txwerks
Yes, the R4's are the biggity BOMB with B's loaded up front in the Wilwood's!
Old Jan 30, 2007 | 05:36 PM
meb's Avatar
meb
Personally, I feel the Mini's rear brakes have too much bias. There are only two areas where my 99Si is better than the Mini; better front end geometry and braking deep into a turn. The Si kills my Mini braking deep. It's all a trade-off.
bean,
The observation you made betwen the Hoosiers and RA1s is very interesting. I use RA1s and my experience is exactly the same.
Old Jan 31, 2007 | 06:06 AM
bean's Avatar
bean
meb: i played w/ damper settings and still couldn't get the car to feel comfortable w/ the RA-1's. in talking w/ more experienced track drivers that had bbk's, they all experienced the same thing. they said "live with it and don't trail brake". i didn't like the feeling. with no suspension changes, the car was rock steady under threshold braking with the hoosiers. i'll try the porterfield R4 in the rear w/ poly b's in the front, but be prepared to switch back to oem rears if i loose that good feeling.....
Old Jan 31, 2007 | 06:28 AM
rataha's Avatar
rataha
I went through rears in about 18000 miles I think the DSC is much more active than we realize and is constantly on the rear brakes Juust my humble un educated impression
Old Jan 31, 2007 | 10:13 AM
meb's Avatar
meb
...but I don't have DSC. ASC is turned off at the track.
Do the Porterfields posses more bite, or less? My car is always loose during threshold braking - stock or modified. And so, I've never attempted to trail brake.
My Wilwoods are the 12.4" race kit with Poly B pads...the spring and damper kit I have may also be part of the problem...
Old Jan 31, 2007 | 10:54 AM
bean's Avatar
bean
the porterfields will have more torque. i'm hoping that the increase from oem is propotional to the increase from BP-20's to poly B's. does anyone else out there have this same issue? it is not comfortable, at all. i inadvertantly trail braked in the center of turn 17, during the 4-3 shift (a long, high speed 180). the car rotated immediately. i nailed the go pedal and came flying out of the turn faster than i had ever managed before. if i had the skill to do this every lap, that would be my line. i stumbled across a solution with the switch from RA-1's to Hoosier 225/40/17 R6's. i played w/ damper settings w/ the RA-1's, but never got to the point where i changed spring rates. DSC was a non-issue for me, as it only kicked in on turn 7 (hairpin) at sebring. i turned if off after becoming comfortable with the handling of the hoosiers. it was my security blanket for a few laps.
Old Jan 31, 2007 | 01:31 PM
meb's Avatar
meb
I think the DSC is a smart option until you get comfortable...top side down is not so comfortable
W0TM8
Dec 19, 2019 07:50 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
