Drivetrain Boost Gauge Buzzing...
Old Jan 24, 2007 | 07:30 AM
van868's Avatar
van868
I just installed Mini OEM Aux Gauges. The boost gauge buzzes all the time especially when making boost. kinda annoying now after a week. don't know how long i can manage. is this buzzing normal?
thanks in advance for the feedbacks.
van
Old Jan 24, 2007 | 08:31 AM
Bahamabart's Avatar
Bahamabart
van
While I am using a VDO - it makes no noise. Return it and get another.
Old Jan 26, 2007 | 09:55 AM
chadtoolio's Avatar
chadtoolio
OOh OOh, I know...I did the same thing... The vacuum "T" that you have going to your intake is installed wrong. If you install the "T" so that the original hose takes the straight path through the "T" and the Boost gauge hose comes in from the side, your problem will be fixed.... I spent a couple of hours on that one...
Chad
Old Jan 28, 2007 | 06:08 PM
van868's Avatar
van868
Chad
my install was its the fuel regulator line takes the straight path through the "T" and the Boost gauge. should I change the line of the fuel regulator with the intake? please advise.. thanks
Old Jan 28, 2007 | 08:03 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
FPR (fuel pressure regulator) works fine on my AutoMeter gauge...
I you got the MINI gauges kit, bring it back for an exchange!
Old Jan 29, 2007 | 12:34 AM
MadMick's Avatar
MadMick
Just put a smal fuelfilter in the pressure line and the buzzing disappers!
Old Jan 29, 2007 | 12:35 AM
MadMick's Avatar
MadMick
Old Jan 29, 2007 | 07:58 AM
chadtoolio's Avatar
chadtoolio
How can you comment on the particular set of gauges he got and tell him to return them without them being installed like the instructions said. There is nothing wrong with the gauge set. I have put on about 6-7 of these kits without incident after I learned my mistake from the first install.
The correct location to tap into the intake is on the corner closest to the pass. side. The one that is a real b***h to get to.
Chad
Old Jan 29, 2007 | 10:56 PM
van868's Avatar
van868
Chad
THANKS FOR THE INSIGHT CHADTOOLIO. IS THIS DIAGRAM CORRECT?
PLEASE CHECK OUT ATTACHED PIC.
Old Jan 30, 2007 | 08:52 AM
kapps's Avatar
kapps
I think he means the boost gauge should be attached to the top part of the T in those drawings.
Old Jan 30, 2007 | 05:09 PM
chadtoolio's Avatar
chadtoolio
No, both of those are incorrect. There is a vaccum line that runs to the corner of the intake manifold closest to the Pass side of the car. Pull this line off and plug it onto the T where you have the Boost gauge hose plugged on. On the side of the T directly opposite where you plugged the hose on, put about a 1 1/2" piece of Vac. hose on and put it onto the nipple where you removed the hose from the intake. Now, the only open port on the T is where you will plug on the boost gauge hose. I think what causes the buzz is the pulses created from the intake/SC and it is harder for the Pulses to turn the corner on the T. If you put the Boost gauge hose straight inline with the intake hose and T, the pulses can flow straight through, right to the gauges.
Chad
Old Feb 1, 2007 | 02:28 AM
van868's Avatar
van868
Thanks Kapps i tried doing your approach. No buzzing and power felt smoother than the time i installed it the wrong way.
This is why i like this forum. people help out each other.
regards to all of the above who helped.
van
Doc Pain
Oct 28, 2015 07:09 PM
Oct 1, 2015 12:13 PM
papawhiskey
Sep 30, 2015 02:50 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
