oil drain plug - must be replaced?
Old Jan 20, 2007 | 06:32 AM
javelina1's Avatar
javelina1
my MINI clipped 1,500 miles last week. Used the opportunity to change the oil & filter. Mainly to get all the break-in crap out. Plus, I also filled it with the German Castrol 0W30. (Engine is humming just fine. Seems to love that stuff).
Quick question. I've seen some DIY instructions saying that you must replace the oil plug when changing the oil. "The seal is integral to the plug". Well I figured as much. I don't have any leaks. For future reference, should one install a new oil plug too?
Old Jan 20, 2007 | 06:42 AM
cristo's Avatar
cristo
Alliance Member
I didn't do it last time I changed the oil, but since then I picked up a couple
oil pan plugs at the dealer, and will change it next time around. They're
pretty cheap, actually.
I think most people don't change the plug with every change.
So, you should, but you don't absolutely have to.
Old Jan 20, 2007 | 06:46 AM
goin440's Avatar
goin440
I have 116k miles on my car and have never changed the plug. I have not leaked any oil, ever.
Old Jan 20, 2007 | 06:54 AM
kenchan's Avatar
kenchan
this is the one car i dont replace the bolt or the washer.
Old Jan 20, 2007 | 07:06 AM
Uncle_John's Avatar
Uncle_John
I use a Fumoto Valve
Works good for me.
Old Jan 20, 2007 | 07:31 AM
norm03s's Avatar
norm03s
Works good for me.
Works for me too!
Old Jan 20, 2007 | 07:41 AM
kenchan's Avatar
kenchan
^ no drips?
Old Jan 20, 2007 | 08:33 AM
Uncle_John's Avatar
Uncle_John
Originally Posted by kenchan
^ no drips?
It's a spring loaded ball valve, no leaks in 5 years of using them.
Old Jan 20, 2007 | 08:40 AM
kenchan's Avatar
kenchan
yah, i know wat they are. ive seen some that leaked from the threaded
part of the valve.
Old Jan 20, 2007 | 09:33 AM
javelina1's Avatar
javelina1
cool beans! thanks for the data point.
Old Jan 20, 2007 | 09:34 AM
javelina1's Avatar
javelina1
Works good for me.
I'll stick with "old school". Ye old OEM drain plug. With the Rhino Ramps, no
issue to change. Now if I can only find some more $10 rebates for GC 0W30....
(that "stuff" is magic in bottle..).
Old Jan 20, 2007 | 09:41 AM
Uncle_John's Avatar
Uncle_John
part of the valve.
Mine have come with a fiber washer. I do use a couple of turns of teflon tape on the threads, but that's just habit.
Old Jan 20, 2007 | 09:48 AM
Yo'sDad's Avatar
Yo'sDad
If I lived in AZ, I would consider using 5W or even 10W30.
YD
Old Jan 20, 2007 | 09:57 AM
javelina1's Avatar
javelina1
YD
The GC 0W30 tends to lean towards the W40 side, (per "Bob is the Oil" guy website).
I've heard of folks around here running W40 Mobil synthetic too.
From Bob's site, the GC should hold up fine here in Phoenix. True, GC can hold up fine, it's the filters I'm worried about. I won't push more than 7,500 miles per oil change, even with FULL synthetic oil. I wouldn't go that far with the dealership 5W30 "cracked" syntec. Maybe 3 or 4K miles per change, with that "stuff".
Just my preference... If folks want to push their cars to one year or 12/15K miles. Fine, they can live with it. Oil is cheap insurance. 7,500 miles per change with full synthetic. No prob!
Old Jan 20, 2007 | 10:30 AM
kenchan's Avatar
kenchan
that's a good habit. i was thinking about getting one on the legacy
cause i change oil on that car the most.
Old Jan 20, 2007 | 01:34 PM
Crashton's Avatar
Crashton
My guess is the drain plug will last for many oil changes. I will replace it when the time comes. A new one is kept on my garage shelf just in case. Buying one before its needed will save a headache later.
Old Jan 21, 2007 | 08:14 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The drain plug should easily outlast the car, as long as it's not overtightened. The bolt is not what wears (unless you use pliers or open-ended wrenches on it instead of a box-end or socket) but the captive o-ring. There is no reason to change the plug at every interval, and it will definitely let you know if it were failing without a catastorphic leak. At most you would see a drop accumulate after a while. Replace it then.
Old Jan 22, 2007 | 05:01 AM
AntiqueCarNut's Avatar
AntiqueCarNut
Originally Posted by Greatbear
The drain plug should easily outlast the car...
But the threads on the aluminum oil pan may not last that long. It's commom for these threads to get worn/stripped past the point of usability. That's the primary reason people install the Fumoto valve on a MINI.
Old Jan 22, 2007 | 10:15 AM
Greatbear's Avatar
Greatbear
This is true too. The primary reason for stripped oil pan threads is overtightening the bolt or cross-threading it on installation. Even the stock tightening spec is really higher than necessary. An o-ringed plug like the one on these cars does not need the cranking that used to be necessary on older cars with steel oil pans and metal-to-metal sealing. The Fumoto valve makes removing the plug unecessary and can make for a tidier draining operation.
Old Jan 22, 2007 | 02:02 PM
Crashton's Avatar
Crashton
For the 95 cents the drain plug cost me there's no reason not to have a spare handy. I am not a fan of a Fumoto valve. It's likely to snap off it hits anything. I know my drain plug won't snap off.
Old Jan 22, 2007 | 02:11 PM
kenchan's Avatar
kenchan
considering i only do an oil change once a year, i don't think that bolt's
ever going to wear out before im done with the car.
Old Jan 22, 2007 | 02:32 PM
kapps's Avatar
kapps
It shouldn't as long as you don't torque the crap out of it. I'm at 50k and have never replaced the plug. Our Honda Insight has a Magnesium oil pan (very easily stripped) and, while the Aluminum crush washer needs to be replaced every time, the pan hasn't stripped in 90k miles of 5k mile oil changes
silence2-38554
98
Sep 21, 2016 02:52 PM
tr3y003
Oct 22, 2015 10:48 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
yashmack
Aug 15, 2015 10:16 AM
azntaiji
Aug 13, 2015 03:24 PM
