strange beep when accelerating from stop
Old Jan 15, 2007 | 11:20 AM
meng's Avatar
meng
Here is a strange noise that I have never heard before in any car I have owned or driven and was wondering if anyone have any info. From stop, as I start to accelerate in first gear, i get a faint "beep, beep, beep" seemingly from under or behind the car. If I slow down and gas it real quick it makes the same noise. Same noise when i reverse from a stop. No noise any other time. Now the noise is as I described: a faint beep. At first, I thought cars behind me was giving me a light beep on the horn to tell me to go until I realized I was getting this noise almost every time. My exhaust is loose and needs to be welded/ tightened up but its strange because it only happens in 1st gear. Strange...
Old Jan 15, 2007 | 11:27 AM
agranger's Avatar
agranger
Is the interval between the 'beeps' the same at different engine speeds (RPM)? Does it vary with ground speed (MPH)?
I've heard of some clutch 'pinging' or 'tapping' sounds... never a beep before.
I can't wait to hear the rest of this story...
Old Jan 15, 2007 | 11:34 AM
meng's Avatar
meng
its not tapping and the sound doesn't correlate with engine speed as you indicated. It is a quick two or three beeps upon lift off. The strange thing is that if I am going real slow like under 5mph, no beep but once i go alittle faster i get it.
Old Jan 15, 2007 | 11:43 AM
07PepperS's Avatar
07PepperS
has the temp outside dropped to 37 or cooler? if so, its telling you to keep a lookout for ice.
Old Jan 15, 2007 | 01:48 PM
Foxtrot_Xray's Avatar
Foxtrot_Xray
It's an explosive device. Once you hear the beeps, if you drop under 60MPH, you'll go 'boom'.
Seriously, I have no clue. Beeps from outside?
Me.
Old Jan 15, 2007 | 04:41 PM
agranger's Avatar
agranger
That's a possibility. When you hear the beeps, look down at the tach. If you see the exterior temp flashing, the MINI is warning you that it's cold outside and there might be ice.
It sounds like this happens with every launch, so that's probably not it, though. My ice warning only happens once for every start/stop cycle of the car.
Old Jan 16, 2007 | 02:43 AM
daleCarlsbad's Avatar
daleCarlsbad
Call the Dealer..................and let us know what they say. thanks
Old Jan 16, 2007 | 02:48 PM
meng's Avatar
meng
weather has been great so no ice. What is a clutch pinging and when would that happen?
Old Jan 16, 2007 | 05:12 PM
herbie hind's Avatar
herbie hind
maybe it's a ding ;and not even close to a beep. if you've got in inner ear dissorder or an infection it could very well be a ping or ding . if so i'd look at the heat sheilds or exhaust straps to be sure nothings dinging. they act up mostly from a stop .
Old Jan 17, 2007 | 07:22 AM
stevecars60's Avatar
stevecars60
Do you have an OE navigation system?
If so, there is a speed warning, sounds like a "fasten seat belt" on an airline. You would find this in the setup menue. The default is 1 - 5 mph.
Old Dec 18, 2020 | 11:55 AM
Brian Fitzpatrick's Avatar
Brian Fitzpatrick
my 2002 330ci does the same thing
Did you ever get a cause to this, my car does the same thing and only in `1st gear and only under 10 mph...
dinomaniac
Sep 18, 2018 04:19 AM
rustof
11
Sep 25, 2015 10:35 AM
thadscottmoore
Sep 25, 2015 10:07 AM
MiniLes
Sep 18, 2015 07:09 AM
gzaos
Sep 14, 2015 04:21 AM
