Service Engine Soon Light
Old Jan 13, 2007 | 05:10 PM
Gromit801's Avatar
Gromit801
Just came on for the first time, and there's still 3000 miles to go. Should it have come on this far from the service interval? Will it go out, or will it remain annoyingly on for the next 3000 miles?
Old Jan 13, 2007 | 05:57 PM
NMgokart's Avatar
NMgokart
Gromit, the SES is not a service interval indicator; it means something is wrong somewhere. Get yourself to an AutoZone and have them read the code that set the light (if you don't have a code reader). If they can't tell you what the code means, post it here for some help.
kenchan's Avatar
kenchan
ses is usually related to emissions, not really your service schedule.
Old Jan 13, 2007 | 05:58 PM
kenchan's Avatar
kenchan
doh! simultaneous post!
Old Jan 13, 2007 | 05:59 PM
Motor On's Avatar
Motor On
How far is your dealer (sounds like your under warranty)? If you go in and you're close they will sometimes go a bit early and save you the trip if its a long drive.
Old Jan 13, 2007 | 06:24 PM
NMgokart's Avatar
NMgokart
Was it good for you?
Old Jan 13, 2007 | 08:11 PM
Gromit801's Avatar
Gromit801
About an hour away. C r a p.
The light came on while my wife was driving, and she tells me that there was no change in the performance or sound.
Old Jan 13, 2007 | 08:16 PM
Motor On's Avatar
Motor On
Stop by an Autozone it may be something small, that you can fix quickly, wait until you need the oil change or may have to make an appoinment for.
Gromit801's Avatar
Gromit801
If the local AutoZone has a code reader, where do I tell them to plug it in?
Hound_va's Avatar
Hound_va
Autozone or another parts house close? That way you could at least have the codes read to give you some idea of what you're dealing with.
Old Jan 13, 2007 | 08:19 PM
MiniMac2005's Avatar
MiniMac2005
^^ Get it checked out if the SES light stays on for a few days. I had my light go on after I filled up with different gas (usually use Mobil.. used Speedway once) after I filled up with my normal gas, the light has not come back on...
Old Jan 13, 2007 | 08:22 PM
Gromit801's Avatar
Gromit801
Well, tomorrow will tell the tail. I'll go by the local AutoZone, see what the code is. Hopefully I'll figure out where to find the plug-in.
Old Jan 13, 2007 | 08:29 PM
xsmini's Avatar
xsmini
Driverside foot area, left side just about where the hood release would be on a normal car. Has a little cover on it that flips down. Just lay on your back with your head under the steering wheel and you'll be sure to see it.....
Nik
Old Jan 13, 2007 | 08:30 PM
Gromit801's Avatar
Gromit801
Thanks XS. Much appreciated.
Old Jan 13, 2007 | 08:33 PM
Partsman's Avatar
Partsman
Legion_of_Doom
To the left of the steering wheel, under the dash there is a little door,
pop it open and the OBDII connector is right there...
the cover that says OBD will be facing the floor, number 2 is the where you will
plug in the code reader.
Old Jan 13, 2007 | 08:42 PM
Gromit801's Avatar
Gromit801
Thanks for all the help.
Old Jan 13, 2007 | 10:15 PM
Electric Shock's Avatar
Electric Shock
I have had my SES light on a few times. Each time it was the O2 sensor.
Old Jan 13, 2007 | 10:37 PM
Gromit801's Avatar
Gromit801
O2 sensor at 7000 miles?
Old Jan 13, 2007 | 10:39 PM
Motor On's Avatar
Motor On
Wouldn't suprose me remember these cars run extremely rich.
Old Jan 13, 2007 | 11:02 PM
NMgokart's Avatar
NMgokart
Keep in mind that the light is triggered by an out-of-spec reading from one of the sensors. Doesn't necessarily mean that the sensor is bad. This could be as simple as the fuel cap not being snugged down properly, or MiniMac2005's case of bad gas .
Old Jan 13, 2007 | 11:09 PM
Motor On's Avatar
Motor On
Lets find out the code first
Old Jan 14, 2007 | 06:54 AM
Electric Shock
I have 30,000 miles and it has happened at 15,000 miles and 28,000 miles. This has happened to many others as well. The good news is that it is no big deal usually. https://www.northamericanmotoring.co...ad.php?t=86048
Old Jan 14, 2007 | 07:00 AM
Uncle_John's Avatar
Uncle_John
My 2002 S ate three O2 sensors in 25,000 miles. The 04 and 06 have never thrown a light.
Old Jan 14, 2007 | 08:10 AM
chows4us's Avatar
chows4us
Ahh ... the joys of MINI ownership.
Its actually better to just pick up a cheap Actron code reader and it can reset the code ... no need to go to the dealer if its nothing like the gas cap
Old Jan 14, 2007 | 09:48 AM
SRTech's Avatar
SRTech
Make sure the gas cap is on tight. It's embarassing to go to the dealer when that's the only problem.
Steve
