Unidentified noise. Help!
Old Dec 28, 2006 | 07:49 AM
goaljnky's Avatar
goaljnky
This is going to be a little hard to explain. My '05 MCc has developed a noise that I am trying to identify. It happens when I start the car in the morning. It sounds like something is hitting. Metal on metal. If I immediately shut the car down and start it again, the noise is no longer there. I believe this is a recent development, less than a month. I did not hear this when it was warmer, although I am not sure weather has anything to do with it. It also does not do it at the end of the day, even though the car has been sitting in the garage for 9+ hours at work and is completely cooled down.
So, does anyone have any ideas?
Old Dec 28, 2006 | 08:19 AM
NMgokart's Avatar
NMgokart
Location of noise?
Old Dec 28, 2006 | 08:31 AM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
Exhaust hangers broken? Heatsheald loose?
Old Dec 28, 2006 | 08:42 AM
goaljnky's Avatar
goaljnky
The noise is coming from around the left hand (driver's) side in the vicinity of a firewall. What's puzzling is that it only happens in the morning when I start the car. As said above, if I shut the car off right away and start it again, the noise does not happen.
Old Dec 28, 2006 | 08:45 AM
NMgokart's Avatar
NMgokart
Do you hear it with the key in run position, but not cranked? or only with engine running?
Old Dec 28, 2006 | 08:50 AM
goaljnky's Avatar
goaljnky
It happens when I start the car. On the first crank. Single noise that sounds like a metal bar hitting a metal pipe. <BANG>. Does not get repeated till next morning.
Old Dec 28, 2006 | 08:57 AM
NMgokart's Avatar
NMgokart
OK, just some possibilities off the top of my head: check the belt tensioner for smooth operation, and check to see that the exhaust hangers are not letting things move around too much. I know these aren't in the left firewall area, but sounds can get transmitted in different ways.
Best bet is to have someone looking under-bonnet when you crank the car.
Also, if a motor mount is broken, you could get some excessive movement of the engine, allowing things to bump which normally wouldn't.
Good luck.
Old Dec 28, 2006 | 09:00 AM
miminut's Avatar
miminut
Did you check the passenger side upper engine mount for leaks?
Old Dec 28, 2006 | 09:20 AM
goaljnky's Avatar
goaljnky
Yes I did. Does not look like it is leaking, but I will be putting in some urethane bushings next week.
Doc Pain
Mar 10, 2021 04:50 AM
Khai
Feb 10, 2016 07:43 PM
Hobine
Oct 7, 2015 04:52 PM
Chefben63075
Oct 1, 2015 12:04 PM
deputydog95
12
Sep 12, 2015 06:49 PM
