Question regarding part
Old Dec 25, 2006 | 12:26 AM
ubaid1's Avatar
ubaid1
does anyone know what this part is called? I need to get mine replaced. Im referring to the black plastic piece above the wheel. thanks
Old Dec 25, 2006 | 12:40 AM
Gromit801's Avatar
Gromit801
Plastic wheel arch is what I would call it.
Old Dec 25, 2006 | 12:42 AM
ubaid1's Avatar
ubaid1
Thanks. Anyone know how I can go about installing one, either by myself or through someone? Is there a DIY for it?
Edit: Ordered it through minimania
Old Dec 25, 2006 | 12:43 AM
Gromit801's Avatar
Gromit801
Check with a dealer service department. Sometimes they'll advise you, or get a Mini service book.
Old Dec 25, 2006 | 12:48 AM
dimini's Avatar
dimini
I have seen some threads on painting arches, which discuss diy installs of arches and areo kits. What I recall is that everyone recommends buying new clips as the old ones apparently break off during removal.
I think most of the sane folks with DIY experience are sleeping right now. Check back after the presents are open...
Old Dec 25, 2006 | 03:45 AM
jeffc's Avatar
jeffc
7th Gear
I had to replace the clips on one of my front ones they just snap right on. Very easy to do but I am not sure if the back ones are the same.
Old Dec 25, 2006 | 10:01 AM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
Try Motoringfile.com. Look up Aero kit install. I think the PDF will give you a how to.
Old Dec 25, 2006 | 12:28 PM
K4KAS's Avatar
K4KAS
Little whits clips that slide onto the arch itself. They attach to little studs welded to the fenders. Then on the very ends there is a standard black clip that inserts itself into hole in the fender. The black ones are usually the ones that break. cheap and easy to replace. Dealer should have them in stock.
Old Dec 25, 2006 | 01:47 PM
Good-Karma's Avatar
Good-Karma
From: Spring City, PA/Williamsport, PA/Benton, PA/Devon, PA
You saying us insane ones arent good enough
AAHHHHimpatientimpatient
confused::impatient
:impatient
Old Dec 25, 2006 | 02:45 PM
Smokey's Avatar
Smokey
Once you pull the inner fender liner, it'll be obvious.
The fender liner comes out with the removal of a few plastic expanding clips and one or 2 real screws. The screw heads on the clips will unscrew (you might have to hold the clip part itself to stop it from turning) and then the entire clip will pop out.
blackie
Aug 23, 2015 08:44 PM
Bennyboy
Aug 18, 2015 07:28 AM
elightbo
Aug 17, 2015 01:50 PM
nomar116
Aug 10, 2015 11:24 PM
