R50/53 The case of the mischievous valet key
Old Dec 21, 2006 | 09:31 PM
eastmtmini's Avatar
eastmtmini
When using the spare key my door locks would go crazy. As I took off down the road the door locks would lock automatically like they should but would mysteriously unlock as I drove a little further. This unlocking/locking repeated continually. I mentioned this to the mechanic when I took the '06 MC in for it's first service. He asked to see the key and immediately saw the problem. The spare key and the valet key where on the same ring. He said the valet key has a magnetic strip inside that interferes with the other key's transmitter so taking the valet key off the ring should fix the problem (I'm paraphrasing here). Likely story I thought but it worked. Other people had come in with the same problem and he said they had to do alot of head scratching to figure that one out.
Old Dec 22, 2006 | 04:50 AM
Murmini's Avatar
Murmini
Fascination... The antenna for sensing the key surrounds the ingintion switch.. you can test it by bringing a key near to it and you will here the familiar "key in the ignition ping!" even when it is just located near the antenna.
Old Dec 22, 2006 | 06:59 AM
Little bit's Avatar
Little bit
This does not work on my 04 MC, is it only on certain models?
Old Dec 22, 2006 | 01:56 PM
Monk Edsel's Avatar
Monk Edsel
I think that didn't start until the '05's. It doesn't work on mine either.
Old Dec 22, 2006 | 02:57 PM
Paul!'s Avatar
Paul!
No, it works in the '04s too. I used to do it in my '04 Cooper.
Remember when trying to set off the 'ding' to have the driver side door open!
-Paul!
Old Dec 22, 2006 | 02:59 PM
Monk Edsel's Avatar
Monk Edsel
-Paul!
Oh! Maybe that's it then!
joedotmac
Oct 23, 2015 11:32 AM
Nicefeet
Sep 24, 2015 06:53 PM
kevins
Sep 23, 2015 12:12 PM
Chiro444
Sep 22, 2015 02:31 PM
MiniUnz
Sep 21, 2015 12:32 PM
