R50/53 Spirited driving and DSC light...
Old Dec 15, 2006 | 01:15 PM
200-OK's Avatar
200-OK
A few times now I've noticed my DSC light going on after spirited driving. Last year there was a post along a similar vein:
https://www.northamericanmotoring.co...=DSC+Indicator
I only have a 15% reduction Alta; should I really be exceeding the boost limit that triggers DSC to shut off?
Anyone else with a 15% pulley seeing the same thing?
Old Dec 15, 2006 | 03:15 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
The DSC isn't triggered by boost. A loss of traction triggers the DSC. I used to find it easy to break my wheels loose with a non-modified 03 MCS. An 06 with a 15% pulley should be easily able to light up the DSC light on a regular basis.
Old Dec 15, 2006 | 03:27 PM
200-OK's Avatar
200-OK
Thanks for the post. I should have been a little clearer... The light stays on and doesn't go off. You are right, I get the flashing DSC light all the time (esp in snow) .
What concerns me is the few times it's gone on recently without going back off (until the car is turned off/on). Per the post I refer to above, someone posted last year that this condition might be tied to hitting a boost threshold...but most of the discussion centered around mods with a 19% reduction...
Old Dec 15, 2006 | 03:31 PM
ChrisW's Avatar
ChrisW
So it goes on and stays on without you turning it off?
Old Dec 15, 2006 | 03:34 PM
200-OK's Avatar
200-OK
Yes, the indicator light goes on and stays on without me touching the DSC controls.
I was going to call the dealer and take the car in, but according to the post above this might be caused by my reduction pulley. They won't cover that under warranty; hence the reason I'm looking for some clarification...
Old Dec 15, 2006 | 03:40 PM
AliceCooperWA's Avatar
AliceCooperWA
I've had this happen to me a couple of times...and I have an MC. I don't think it has anything to do with boost. The couple of times it has happened to me is if the car is warm from being recently driven, I will turn it on and take off right away. It seems like if I activate the DSC by losing traction right after turning the car on, it stays on. Maybe it is just a warning of hazardous conditions? I don't know why it does it. For me, it always turns off on its own after 5 or 10 minutes though.
Old Dec 15, 2006 | 05:45 PM
200-OK's Avatar
200-OK
I see something similar when driving in snow. But with the "spirited driving", it can't be turned off until turning off the car...
Old Dec 15, 2006 | 05:52 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
Do you notice a reduction in power? Or do you still have full power even while the light is on?
Old Dec 15, 2006 | 05:54 PM
200-OK's Avatar
200-OK
Full power, but I probably tone down the driving a bit since the DSC is off...
Funny this seems to happen only when I am running late..??
Old Dec 15, 2006 | 10:32 PM
coloradomini's Avatar
coloradomini
I had this happen. Took it to the dealer and they told me the oxegen sensor shorted out replaced it and reset. Was better. But when the light came on and stayed on other electrical equepment like A/C would not work at that time.
Old Dec 16, 2006 | 12:14 PM
200-OK's Avatar
200-OK
Thanks for the tip. I'll check this out next time it happens...
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
Drumsound
Aug 25, 2015 05:22 AM
Steffen.Johnson
Aug 23, 2015 08:30 PM
Powershift
Aug 16, 2015 05:14 PM
