Navigation & Audio Weak FM signal on Alpine head unit
Old Dec 10, 2006 | 12:31 PM
soilsample's Avatar
soilsample
Hello all,
I've recently upgraded to an Alpine 9857 head unit. I'm having weaker FM reception with the Alpine than I did with the stock head unit. I was told that Alpine is notorious for weak FM Reception......
Would an FM booster help?
I don't want to add more electrical junk to my dashboard area if it won't work.
Has anybody else tried an FM booster? Could you recommend a particular brand/model.
Thanks in advance
Donald
Old Dec 10, 2006 | 02:09 PM
Giants9595's Avatar
Giants9595
I have an Alpine 9855 deck and was able to get better reception than the stock head unit. Make sure you are using the euro to american coverter and make sure your powere antenna cable is connected and connected VERY securely. I reconnected my power antenna wire and was able to get better reception.
Old Dec 10, 2006 | 04:29 PM
ScottinBend's Avatar
ScottinBend
Yes.......definitely check the antenna connection. Mine was real loose and it kept getting worse. Finally took it to the dealer and the service guy knew exactly what was wrong. Sounds like it might be a more common problem than most know about.
Old Dec 10, 2006 | 07:27 PM
hugh's Avatar
hugh
Originally Posted by soilsample
Hello all,
I have same complaint. 2 questions:
How many miles and what terrain (hills?) between you and the station transmitters?
What about am reception?
Old Dec 10, 2006 | 10:06 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Make sure that the diversity amplifier (located under the right rear side window under the trim) receives power after the HU swap. There is a solid white colored wire that connects to the original headunit that can be powered by the 'power antenna' output on most aftermarket headunits.
The diversity amp takes the signal from the roof antenna (or side window antenna for early nav-equipped cars) and the rear defroster grid (which is set up to be used as a second antenna) and continuously routes whichever signal is stronger the the HU. Without power, the amp will act as an attenuator and make reception pretty weak on FM (AM is not affected by the amp).
Old Dec 14, 2006 | 01:29 PM
soilsample's Avatar
soilsample
The Euro antenna plug converter that I bought has a +12v wire on it..... it is hooked up to my power antenna +12v outlet on the head unit. It is my understanding that this setup should allow the factory antenna to function normally.
I added a small antenna booster to the system and my performance has increased greatly. The guy at the stereo shop said that some factory antenna are set up to match the factory head unit....... some aftermarket head units need more gain (supplied by the booster).
I'm about 40 miles from the "local" stations...... the more powerful stations always came in strong, but the weaker stations would fade badly. Now I can get the weak stations.
I'm in Louisiana..... not a hill in sight! (ok can't forget the land fill!)
Old Dec 16, 2006 | 10:36 AM
hugh's Avatar
hugh
I'd like to try that.
What kind?...how much $$$ ? ...how to install?
Old Jun 24, 2007 | 03:42 PM
aquaanox's Avatar
aquaanox
Hello all,
Thanks in advance
Donald
I just started a new thread on a similar issue found this post. Did you ever get this resolved ?
thanks
Old Jun 24, 2007 | 08:46 PM
kenchan's Avatar
kenchan
all great suggestions above.
make sure your antenna is still on your roof.
UncDeo
Nov 4, 2019 04:08 AM
Sep 11, 2015 01:15 PM
COOPT UP
Sep 11, 2015 04:59 AM
jesterofatlas
Sep 4, 2015 11:23 PM
