Quick question - can runflats be repaired?
Old Nov 25, 2006 | 12:48 AM
MCDriver's Avatar
MCDriver
can run flats be repaired? i picked up a screw om the running surface and it is loosing pressure.
thanks.
Old Nov 25, 2006 | 01:43 AM
MiniRacerRick's Avatar
MiniRacerRick
Coordinator :: NorCal MINIs
I would think that a run-flat could be repaired the same as a standard tire
by either plugging it from the outside, or patching it on the inside as is done.
Old Nov 25, 2006 | 02:02 AM
cooprd's Avatar
cooprd
I had the same and it was repaired with no problems.
If it was damaged on the side you would need a new tire.
Old Nov 25, 2006 | 03:11 AM
Tit's Avatar
Tit
Some tyre shops will be reluctant to repair a puncture if it's too close to the side-wall. The stiff side-walls are where the tyres get their 'run-flat powers' from, and if that's compromised, then the tyre might not be as 'run-flat' as you might hope...
Old Nov 25, 2006 | 04:32 AM
BlimeyCabrio's Avatar
BlimeyCabrio
The other big factor is whether you drove on the tire with zero (or near zero) air pressure - actually "using" the run-flat capability - if you did for any significant distance, there's the possibility that the tire is structurally compromised (and they can get quite hot when you run on the flat...)
But if you just picked up a screw and found it when the pressure was a little low and it was never truly "run flat" you're probably OK.
Old Nov 25, 2006 | 05:04 AM
abbydog3's Avatar
abbydog3
When I had my runflats, I had them repaired at my local discount tire for free, nail in the tread. It was my understanding it can be repaired as a normal tire, as long as it is not in the sidewall.
However they did scratch my rim - so I guess it wasn't really free.
Since you are in Dallas, I highly recommend the Kauffman Tire. I have bought several sets of tires/wheels from them and they cheaper than discount, performed better service and treated me well.
Cheers.
Old Nov 25, 2006 | 05:12 AM
Uncle_John's Avatar
Uncle_John
thanks.
Yep. I had one fixed at Discount tire on Camp Bowie in FW. When my flat tire light cam on it was down to about 20 psi. Aired it up and went right to Discount. It was a screw in the tread. They did not scratch the rim on mine.
Good luck.
Old Nov 25, 2006 | 05:32 AM
davavd's Avatar
davavd
So, are you saying that if one does actually use the runflat capability, that it ruins an otherwise repairable tire? If so, this would be really good to know about.
Old Nov 25, 2006 | 06:03 AM
Uncle_John's Avatar
Uncle_John
See item 15 in the action.
Runflats work by giving up the life of the side wall over the driven distance while flat.
http://www.autosafety.org/article.php?scid=185&did=1165
Old Nov 25, 2006 | 09:17 AM
scatpack's Avatar
scatpack
I found most places WONT fix a runflat.
Old Nov 25, 2006 | 10:44 AM
ScottinBend's Avatar
ScottinBend
And the reason most shops won't repair a run-flat is because they have absolutely no way of telling how long you may have run on them "flat". The tire shop won't take the responsibility/liability of repairing a run-flat and suffer the possible lawsuit if the tire has a catastophic failure later on. If you can convince the tire shop that it has never been driven on "flat" then you shouldn't have a problem.
Old Nov 25, 2006 | 05:25 PM
MCDriver's Avatar
MCDriver
i got it repaired. damn those s-lites weight a ton.
i went to NTB and they nicked a place in both the tire and the wheel. pissed off.
Old Nov 27, 2006 | 05:13 AM
Chappy's Avatar
Chappy
Yep. I picked up a nail in one had had it fixed at a Discount Tire here in Houston last Tuesday. No problems since then.
I was also told that "they" can tell when a run flat has been "run flat" because it will accumulate a large quantity of black rubber powder inside the tire.
woodstudio
Mar 15, 2020 08:28 AM
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
PhoenixR61
Aug 21, 2015 07:40 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
