Will rims from a tdi jetta fit?
Old Nov 16, 2006 | 08:43 PM
flannelhippie's Avatar
flannelhippie
No. Stop. Im not gonna roll around with lame jetta rims. Im talking about buying some aftermarket rims for an Mk. III from a friend, they are white 6 spoke 15". Light weight for auto x next summer. I dont want to bang up my stock ones till I get nice Anthracite 17". But will these bad boys fit?
Old Nov 16, 2006 | 08:46 PM
RebelToRumble's Avatar
RebelToRumble
wheels...wheels..........
Old Nov 16, 2006 | 08:51 PM
kenchan's Avatar
kenchan
only if they are 4x100 PCD 56.1mm center bore +40 to +50mm offset max 8" width.
Old Nov 17, 2006 | 07:35 AM
DixonL2's Avatar
DixonL2
IIRC VW has a 57.1mm hub bore, 1mm larger than the mini, so they'll not be hubcentric - tighten lugs carefully and you should be good. Don't know the offset, but if it's between 40 and 50 you're probably OK. Need to check brake caliper clearance though, and use appropriately sized tires.
Old Nov 17, 2006 | 07:38 AM
DaddyOfPayton's Avatar
DaddyOfPayton
You are correct on the center bore for the Mk3 (57.1).
I don't know if anyone makes them to go from 56.1 to 57.1, but a hub centering ring would be a good idea. The stock offset for 4 lug VW's of that vintage is usually either -38 or -45 so those will BASICALLY fit the bill
FLYM1N1
Oct 13, 2015 04:33 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
Aug 12, 2015 01:24 PM
